Hello I found difficult to discover any Aqara devices since I’ve switched to home assistant OS.
I am using tic2351 ZigBee.
Before home assistant was installed as docker container and everything was fine, easy to discover and to set up with ZigBee integration on H.A.
In the past I’ve used same devices c2351 and Aqara temperature sensor and it was working.
Could you please give any ideas please. Thx in advance
Which integration are you using and which Aqara devices are you having trouble with?
Thank you for you reply
ZigBee home automation - integration
Xiaomi Mi Smart WiFi plug ZigBee Version
Aqara temperature humidity pressure battery powered sensor
Hi! Have you installed/configured the Xiaomi/Aqara Integrarion?
Take a look at this: https://github.com/AlexxIT/XiaomiGateway3
Cheers,
Joaquín
So you are having trouble with only these 2 devices ? Is that correct ? Do you have any log details/errors perhaps ? Can you share (screenshot) how many devices are in your network and that are working (like your ZHA Map) perfectly fine ?
Something like this image to see what you have.
Also; the coordinator you are using (cc2531) is not really recommended, and has/can/does have issues. Better you go for something like this as your coordinator and have one of these to help with any possible interference issues.
Don’t worry , the cc2531 you can re-use as a router in your setup as described here
