after updating my HA from 7.2 >> 7.3 Zigbee stopped working out of a sudden. There are no logs or any messaged which indicates there is anything wrong. It just stopped. When moving a switch (e.g. from poweron to poweroff) just nothing happens.
I restored my config to yesterday - nothing happend. I also unplugged and re-plugged the zigbee ConBee stick.
I even waited overnight in the case my entities needed some time to recover from the update, also without success. All other devices and entities are working without any problems and issues.
No, not in the WEBUI, I have been been through all available logs. Attached the log of āeverythingā - canāt find anything that gives a hint to ZigBee. And as you can see in the attached file - no errors on the surface.
Hi, sry, i did filter for the wrong keyword (instead of zha i took zigbee), but anyway, I have been though all 3 suggestions. It neither the interfering with my WiFi channel and I did re-plugging differn times and the ConBee Stick is recognized without issues. I do have 112 zigbee entities in 3 stories and all have been worked nice before the update to 7.3.
Hi, that was exactly my intention, downgrade the homeassistant server to version 7.2 again and then waiting up for some kind of āpositiveā behaviour in regards of the zigbee entities.
But I did not get involved how to do that yet, the downgrade. Canāt do that with my backup files that much all figured out.
I did only find some hints and clues how to down create the core and the supervisor. That seems pretty straightforward and easy, but afterwards the system itself will obviously stay at version 7.3:(
Ok, I downgraded the core too some version 14 days ago. It is now Version 2021.12.10. But the zha error in the log stays - always the same:
[homeassistant.components.zha.core.channels.base] [0x3FE8:3:0x0300]: async_initialize: all attempts have failed:
Ok, I succeeded also with downgrading the operating system from version seven point three to seven ppint two and afterwards all the ZigBee entities have been working again. So problems solved after downgrading the OS. But now? I do not dare to update the system since I fear that the same thing will happen again:(
Yes Iām working at RedHat. Thereās really anything about Linux and containers. I myself running several services and programs in containers on my raspberries - with podman (itās very similar to docker but rootless, no service, just a very slender runtime).
Ok, thanks for the heads up and maybe I will give a try on containers as well, maybe the better approach.
Same Issue, Zigbee completely stopped working after 7.3 update from 7.2. Tried restore from snapshot, I however did not have ny luck with that. Remaining on old insecure versions of home assistant is unacceptable anyway, I wouldnāt leave my television on old firmware, let alone the literal brain of my house. Tried to remove addon and readd it, no luck, wonāt find the coordinator. This was after doing extra work to even attempt to get my raspbee 2 to even be seen by home assistant. (Playing in the config file.) Still no luck though, my raspbee 2 and my zigbee is completely borked and I donāt know how to fix it.
