Hi, sry, i did filter for the wrong keyword (instead of zha i took zigbee), but anyway, I have been though all 3 suggestions. It neither the interfering with my WiFi channel and I did re-plugging differn times and the ConBee Stick is recognized without issues. I do have 112 zigbee entities in 3 stories and all have been worked nice before the update to 7.3.
Hi, that was exactly my intention, downgrade the homeassistant server to version 7.2 again and then waiting up for some kind of “positive” behaviour in regards of the zigbee entities.
But I did not get involved how to do that yet, the downgrade. Can’t do that with my backup files that much all figured out.
I did only find some hints and clues how to down create the core and the supervisor. That seems pretty straightforward and easy, but afterwards the system itself will obviously stay at version 7.3:(
Ok, I downgraded the core too some version 14 days ago. It is now Version 2021.12.10. But the zha error in the log stays - always the same:
[homeassistant.components.zha.core.channels.base] [0x3FE8:3:0x0300]: async_initialize: all attempts have failed:
Ok, I succeeded also with downgrading the operating system from version seven point three to seven ppint two and afterwards all the ZigBee entities have been working again. So problems solved after downgrading the OS. But now? I do not dare to update the system since I fear that the same thing will happen again:(
Yes I’m working at RedHat. There’s really anything about Linux and containers. I myself running several services and programs in containers on my raspberries - with podman (it’s very similar to docker but rootless, no service, just a very slender runtime).
Ok, thanks for the heads up and maybe I will give a try on containers as well, maybe the better approach.
Same Issue, Zigbee completely stopped working after 7.3 update from 7.2. Tried restore from snapshot, I however did not have ny luck with that. Remaining on old insecure versions of home assistant is unacceptable anyway, I wouldn’t leave my television on old firmware, let alone the literal brain of my house. Tried to remove addon and readd it, no luck, won’t find the coordinator. This was after doing extra work to even attempt to get my raspbee 2 to even be seen by home assistant. (Playing in the config file.) Still no luck though, my raspbee 2 and my zigbee is completely borked and I don’t know how to fix it.
Just for the record: “restart” the host is “power cycle” the host.
I am still on 7.1 but when I updated from 2021.12.10 to 2022.2.3 I also lost ZHA - ha core restart did not help - it worked after epowercycling the host.
Maybe removing and re-inserting the zigbee usb key would also have done the trick.
I think its something with the OS specifically. 7.3 & 7.4 are broken. I’ve had no issues with any core updates and just went to 2022.3.1, ZHA works fine.
What stick does everyone have? I have the HUSBZB-1 Zigbee / Z-Wave combo which I know is a little older. Maybe the OS changes removed something the USB stick needs?
I started to use HA in my NUC since 1 January and used always latest updates. I only used 3 or 4 zigbee devices with ZHA and a conbee II. And so far, I didn’t have issues.
