Zigbee Led Panel recommendations?
hey all, i have been looking around a lot for zigbee light panels but i am looking for a very specific kind of light i am unable to find
i am trying to look for:
  • a zigbee wall light (preferably a panel)
  • that is powered through a wall plug (so not like a celling light or powered through the wall)
as far as i can see i have found nothing so i am wondering if anyone has any ideas? i dont mind if they dont follow the specifications exactly just wanting to try and find something as close as i can to this
any help is appreciated!!
Hi, what about still using a ceiling/wall panel that is intended to be powered inside the wall but just attach a cable and a plug to use a wall plug?
have been thinking of that but was just wondering if anyone had any more direct unpack and plug in solutions out the box
You will have more options/choice by not fixating on plug-in panels and how hard can it be to screw a cable & plug.
Have a look here and see if there’s anything you like.
Note that this is the Z2MQTT compatibility list - if you’re using ZHA the devices you see here might not be compatible.
As for the plug part, most of these just come with the connectors - there’s no (external) wires at all. Just hook up a plug on a wire and you’re done - no need to restrict yourself for a 2 minute job.
