Zigbee light bulb temp settings?
I bought several of these MR16 bulbs for my landscape lights. When I first plugged them in they turned on bright white (6500K). After I paired them with HA via ZHA integration the white LED no longer works. I can not turn the bulb to bright white and I can tell that other color temperatures (other than 2700K where the white LED isn’t used) are slightly off. Is there some configuration that will correct this?
half of the bulbs work as normal and the other half have this issue.
