Zigbee Lights briefly show previous settings before changing to the light settings i chose
Hi there! I just switched from my HueBridge to Zigbee2MQTT with a Conbee II. Everything works like a charm and is so much faster than it has been via the Hue Bridge.
Unfortunately there is one small issue, that I don’t know how to solve: If the bedroom lights had been on 100% White before i turn them off, and in the middle of the night my nightlight automation starts (Motion sensor under bed triggers a 20% Red light), it briefly shows the 100% White light before dimming down to my 20% Red light.
Is there a way to change this behaviour in HA or in Z2MQTT?
On some lights it works when I just change the fade to 1 or 2 seconds, but on other lights it doesn’t seem to be working.
Thanks a lot in advance!
