Hi All,
I am new to Home asisstant and Zigbee, i have a couple of lights (Ikea Tradfri) connected with zigbee to my raspberry pi 3 with home assistant (Conbee 2) The lights work perfectly only sometimes i turn the lights on or off with the switch and then the lights reset and lose connection, or the lights are not avaible because the switch is off.
I found a shelly relay Link that you can place behind your socket too keep connection and use both switch and home assisant for the lights.
Will this solve my problem for the lights resetting or wil it only keep connection when the switch is turned of (i am quite a noob with electricity) and what do i need to fix this
