Zigbee mesh stops working with switch to M.2 SATA
Hey all
I have recently bought an Argon One M2 case and installed a SSD in it. I have a wierd issue with Deconz/ConBee II I can’t get my head around.
I’ve copied my existing SD card to the SSD using dd, as far as I’m aware it’s an exact copy. However when I boot the pi off the SSD, everything works except the Zigbee devices. Looking at the Deconz mesh, I see no green lines. If I switch back to the SD card, everything comes up within a few minutes.
Any ideas?
Add a USB extension cable to move the Conbee2 Zigbee radio away from the USB ports. The USB SSD creates a lot of RF noise. This is a very common issue when running a RPi off of a USB drive.
Just wanted to come back for anyone who reads this. Ogiewon’s solution worked, after adding an extension the mesh came up immediately.
Same worked for me.
Thanks.
Sometimes the simplest solutions are the best!
Lesson learned, be sure to always follow best practices → https://github.com/zigpy/zigpy/wiki/Generic-best-practice-tips-on-improving-Zigbee-network-range-and-general-stability
I mean yeah. It’s good advice. But why would I be looking at the ZigPy best practise document when I am running a Conbee stick with Deconz
Read it, the advice there is generic for all Zigbee and nothing mentioned there is specific to zigpy/ZHA.
