I have swing shutters that i plan to motorize with arm motor ( Thomson model).
This le delivered with a proprietary 868mhz radio control, or can be linked to a regular shutter Switch by the use of 3 wires white, green and blue
I did not find any info on the forum about controlling this motor…
And this is the trick, the three wires are only low power control ones, there are not power delivering tension to the motor in one direction or the other. It even says “do not put 220v on it”
There is a white wire, and closing this wire (dry contact) to either of the two other wires will send the signal to the controller to open or close the shutter.
Most of my control are based on zigbee, and I have also, as plan B, possibility to use rfx 433mhz. But I would prefer to use zigbee.
So my question is which zigbee switch or relay module could you advise me to use?
Most of the one I can easily find have the purpose to redirect 220v to the output, and have only one output.
Some have two outputs but also to redirect high voltage, and are not made two by used as “swing switch” ( bascule), with three positions:
Open
White connected to blue
White connected to green
Any zigbee module comes to your mind?
Thanks in advance
Vincent
