Hello, I have setup an automation that drops the house thermostat temperature down when I leave the house. I noticed that although the action is ‘Temperature’ it’s not it’s in fact setting ‘Local temperature calibration’ so the Physical thermostat, was reading 40c not 18! opps!
So I reset the ‘Local temperature calibration’ on the zigbee2mqtt webpage, to -4, as the internal sensor of the Moes is out of calibration, thus
I then went over to HA, to the definition of the Moes device and found the following
Also from the developer pages found the following
Yep looks like ‘Temperature’ is mapped to ‘local temperature calibration’ it should be mapped to ‘current_heating_setpoint’
I can not find where this mapping is configured/coded, does anyone have the same issue.
BTW: The main thermostat control in HA works ok
