Running HA in Docker on a Synology NAS. Recently installed a SONOFF Zigbee 3.0 USB Dongle and a few Zigbee Tuya based motion detectors. I have tried to set up an automation with the motion detectors but I only get Firmware related options in the triggers dropdown. Likewise, if I try to add the device to a dashboard the only card available is showing the firmware status. Is this a driver issue? Thanks
Go to developer tools → events, listen to zha_events, move in front of your motion sensor
Then create the automation using the event trigger with the information you found while listening.
Just to add if anyone has a similar issue - resolved by moving from ZHA to Zigbee2Mqtt
