Hello!
For over a year now I have a few in ceiling presence sensors (more or less unbranded: TS0601 TZE204_xxxxxx devices).
Previously I didn’t have any problems with these, other than the initial installation and quirks that were needed to be able to setup the devices properly.
I’ve created a topic about this around a year ago, see here: Getting ZHA custom quirks to work with Tuya TS0601 in-ceiling motion sensor
The thing is that since i’ve updated from HA 2023.10.x to 2023.12.x the devices sort of stopped working.
Although not quite… What is see is that currently most events (from detected
to clear
state) are not registered at all.
Or if the state changes from clear
to detected
it will not revert back to clear
again. Even after many many hours.
This is obviously quite annoying since they run most of the lighting in the house…
It is not all sensors that are disfunctioning at the same time, but the problem just seem to move every few minutes. Sometimes it works, sometimes it does not.
The interesting bit is that the Illuminance values seems to be updated while motion is not registered at all.
Although this value seems to be old as well sometimes (probably would be better to start monitoring RSSI for instance)
What i’ve tried:
- Cycle power to the devices - This seems to help at first, but only for a few minutes. Or it just moves the problem to other sensors.
- Restart home assistant - Same happens, it works for a bit, then the problem sort of “moves” again.
- Re-plug the SONOFF ZigBee 3.0 stick i am using - Same as above
- Hitting the Migrate radio button on the ZHA integration - Nothing seems to change
- Changing channel from 15 to 20 or 26 - Nothing seems to happen. it still remains on channel 15.
What I did see with one of those options tried above (not sure which attempt anymore) is that i could see in the logs that some devices were going from the available state to the unavailable sate every 2 seconds or so. Only way to get them out of that scenario is to cycle power to them.
What I did see in the logs a day or so ago is that it is logging this:
2023-12-18 09:24:11.528 WARNING (MainThread) [zigpy.application] Zigbee channel 15 utilization is 92.96%!
That is not exactly ideal i think, but that shouldn’t necessarily be a problem?
Not sure if this is related but WiFi and Zigbee use the same frequency: A few months ago I was having many issues with my wireless Shelly devices. I have around 40 of them on the same network. If you are interested in those problems see here
It wasn’t exactly resolved, it just started to work magically again and not having any issues anymore since…
Any help would be appreciated, Thanks!
