I set up my Tradfri bulb in Zigbee2mqtt. I manually configured it in the lights.yaml file as follows:
- platform: mqtt
unique_id: bedroom_ceiling
state_topic: "zigbee2mqtt/Tradfri/state"
command_topic: "zigbee2mqtt/Tradfri/set/state"
payload_on: "ON"
payload_off: "OFF"
# brightness: true
# color_temp: true
# xy: false
# hs: false
brightness_command_topic: "zigbee2mqtt/Tradfri/set/brightness"
brightness_scale: 255
brightness_state_topic: "zigbee2mqtt/Tradfri/brightness"
color_temp_command_topic: "zigbee2mqtt/Tradfri/color-xzigbee2mqtt/Tradfri/color-x"
# effect: true
effect_list:
- "blink"
- "breathe"
- "okay"
- "channel_change"
- "finish_effect"
- "stop_effect"
How can I get the brightness and colour temperature settings into a slider and a drop-down menu on the Lovelace interface? I tried adding a separate entry in input_slider.yaml but I can’t figure out how to link it to the brightness part of the light. I suspect I’m going about this the wrong way. It seems to convoluted to set up a simple thing so any advice would be greatly appreciated.
p.s. If I click on the light it comes up with a little card with the slider which works but I want to be able to do it directly from the interface. Also, there doesn’t seem to be a way to change the colour temperature either. I copied the above from the Zigbee2mqtt website.
