HI!
Dear community, please help to find the answer.
Every time, when Home Assistant Core update appears in Supervisor, my zigbee network crashes. After update everything becomes good.
My Mosquitto brocker config:
logins:
- username: **
password: ***
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
anonymous: false
My Zigbee2mqtt config:
data_path: /share/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
base_topic: zigbee2mqtt
server: mqtt://core-mosquitto
user: **
password: ***
serial:
port: /dev/ttyACM0
advanced:
log_level: info
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist: []
availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
port: 8099
experimental: {}
socat:
enabled: false
master: pty,raw,echo=0,link=/dev/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: '-d -d'
log: false
restartdelay: 1
initialdelay: 1
OS: Home Assistant OS
Raspberry Pi4
Zigbee-stick CC2538
Thank you! Hope for wise advice!
