Zigbee Network Completely Offline
Hello Everyone,
I apologize this is another Zigbee Network Offline message. I did attempt to do my own research ahead of time to fix this issue but I’m a bit stumped right now. I’m at the point I may have to do a factory reset of every device and re-add them. This is a lot of work so I figured I’d ask first.
I have a medium size network all comprised of mains connected light switches from Innovelli. They all act as routers. One day this week, the entire network went down. Every node is red. I assumed if this was a case of interference, some somewhere would be accessible but that does not seem to be the case.
  1. I can attempt to reconfigure the nodes. When doing so, they eventually error out but I do get a green checkmark on the binding and reporting.
  2. When I try to power cycle the switches, at the breakers or the air gap, nothing changes.
  3. When I disconnected the main controller for 3 hours and plugged it back in, None of the devices came back online.
Although, the error message indicates there may be more information in the logs, there does not seem to be anything there of value. There are errors there, but nothing that stands out.
This is the last message that I see when I check the system logs after attempting a reconfiguration.
2025-08-27 14:38:19.712 ERROR (MainThread) [frontend.js.modern.202508111] Uncaught error from Chrome 138.0.0.0 on Windows 10
TypeError: Cannot read properties of undefined (reading 'get')
_handleMessage (src/panels/config/integrations/integration-panels/zha/dialog-zha-reconfigure-device.ts:368:44)
callbackFunction (src/data/zha.ts:218:44)
callback (node_modules/home-assistant-js-websocket/dist/connection.js:23:33)
forEach (node_modules/home-assistant-js-websocket/dist/connection.js:15:25)
After a while - This appears:
Logger: homeassistant
Source: /usr/src/homeassistant/homeassistant/runner.py:113
First occurred: 2:40:10 PM (2 occurrences)
Last logged: 2:44:04 PM
Error doing job: Task exception was never retrieved (None)
  File "/usr/local/lib/python3.13/site-packages/bellows/zigbee/application.py", line 951, in send_packet
    send_status, _ = await future
asyncio.exceptions.CancelledError
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 68, in wrap_zigpy_exceptions
    yield
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 88, in wrapper
    return await RETRYABLE_REQUEST_DECORATOR(func)(*args, **kwargs)
  File "/usr/local/lib/python3.13/site-packages/zigpy/util.py", line 134, in retry
    return await func()
  File "/usr/local/lib/python3.13/site-packages/zigpy/zcl/__init__.py", line 401, in request
    return await self._endpoint.request(
    ...<9 lines>...
  File "/usr/local/lib/python3.13/site-packages/zigpy/endpoint.py", line 234, in request
    return await self.device.request(
    ...<11 lines>...
  File "/usr/local/lib/python3.13/site-packages/zigpy/device.py", line 594, in request
    await send_request()
  File "/usr/local/lib/python3.13/site-packages/zigpy/application.py", line 884, in request
    await self.send_packet(
    ...<14 lines>...
  File "/usr/local/lib/python3.13/site-packages/bellows/zigbee/application.py", line 946, in send_packet
    async with asyncio_timeout(
        MESSAGE_SEND_TIMEOUT_MAINS
        if not packet.extended_timeout
        else MESSAGE_SEND_TIMEOUT_BATTERY
  File "/usr/local/lib/python3.13/asyncio/timeouts.py", line 116, in __aexit__
    raise TimeoutError from exc_val
TimeoutError
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/device.py", line 840, in async_configure
    await self.identify_ch.trigger_effect(
    ...<2 lines>...
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 87, in wrapper
    with wrap_zigpy_exceptions():
  File "/usr/local/lib/python3.13/contextlib.py", line 162, in __exit__
    self.gen.throw(value)
  File "/usr/local/lib/python3.13/site-packages/zha/zigbee/cluster_handlers/__init__.py", line 70, in wrap_zigpy_exceptions
    raise ZHAException("Failed to send request: device did not respond") from exc
zha.exceptions.ZHAException: Failed to send request: device did not respond
Which indicates to me that the device is not responding but I’m not sure why the device did correctly for the binding and reporting settings but not for whatever it was attempting to get in the end.
Here is my network; Many switches act as routers and most devices have multiple paths.
Is there something I can do to restore the network or do I need to factory reset each and every device?
Sorry - New user here. I can only post one embedded image per post, but I figured this may be good information too. I do find it slightly odd that the Serial Port isn’t explicitly the port but if it’s based on ID and it changes ports I suspect it will be mapped correctly if it’s defined this way.
tldr; Factory Reset Every Device and Reconfigured Everything. Total Loss.
Not trying to bump my own thread but in the end I was stuck performing a factory reset on every device in the network. I was not able to restore functionality to the network using any of the built in features.
What was a plus is that HA remembered most of the HA details. This did save some time.
