Zigbee network just went haywire
All of a sudden my Zigbee network just went haywire -
I’m using the Sonoff 3.0 dongle with a USB extension - I have an automation that turns lights on and that’s not been happening after a few days - I started to investigate and the first thing I noticed is when I go to my MAP in Zigbee2MQTT I was getting a bunch of errors. I also wasn’t able to turn devices on and off from HA.
after doing a little research, yesterday I flashed my dongle to ember. I also switched my 2.4 wifi to channel 11
When doing a map discovery I’m getting a bunch of “Failed to Exude LQI for XXXXX [device name]” (as you can see below
In my logs I’m getting the following
Any help or direction to look would greatly be appreciated
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash:   CRC errors      : RX=0
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash:   Comm errors     : RX=0
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash:   Length < minimum: RX=0
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash:   Length > maximum: RX=0
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash:   Bad controls    : RX=0
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash:   Bad lengths     : RX=0
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash:   Bad ACK numbers : RX=0
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash:   Out of buffers  : RX=0
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash:   Retry dupes     : RX=0
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash:   Out of sequence : RX=0
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash:   ACK timeouts    : RX=0
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash: Port closed.
[2024-09-24 07:54:02] info: 	zh:ember:uart:ash: ======== ASH stopped ========
[2024-09-24 07:54:02] info: 	zh:ember:ezsp: ======== EZSP stopped ========
[2024-09-24 07:54:02] info: 	zh:ember: ======== Ember Adapter Stopped ========
[2024-09-24 07:54:02] info: 	z2m: Stopped zigbee-herdsman
[2024-09-24 07:54:02] info: 	z2m: Stopped Zigbee2MQTT
[07:55:29] INFO: Preparing to start...
[07:55:29] INFO: Socat not enabled
[07:55:30] INFO: Starting Zigbee2MQTT...
Starting Zigbee2MQTT without watchdog.
[2024-09-24 07:55:32] info: 	z2m: Logging to console, file (filename: log.log)
[2024-09-24 07:55:32] info: 	z2m: Starting Zigbee2MQTT version 1.40.1 (commit #unknown)
[2024-09-24 07:55:32] info: 	z2m: Starting zigbee-herdsman (0.57.3)
[2024-09-24 07:55:32] info: 	zh:ember: Using default stack config.
[2024-09-24 07:55:32] info: 	zh:ember: ======== Ember Adapter Starting ========
[2024-09-24 07:55:32] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2024-09-24 07:55:32] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2024-09-24 07:55:32] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2024-09-24 07:55:32] info: 	zh:ember:uart:ash: Serial port opened
[2024-09-24 07:55:32] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2024-09-24 07:55:33] info: 	zh:ember:uart:ash: ======== ASH connected ========
[2024-09-24 07:55:33] info: 	zh:ember:uart:ash: ======== ASH started ========
[2024-09-24 07:55:33] info: 	zh:ember:ezsp: ======== EZSP started ========
[2024-09-24 07:55:33] info: 	zh:ember: Adapter EZSP protocol version (13) lower than Host. Switched.
[2024-09-24 07:55:33] info: 	zh:ember: Adapter version info: {"ezsp":13,"revision":"7.4.4 [GA]","build":0,"major":7,"minor":4,"patch":4,"special":0,"type":170}
[2024-09-24 07:55:34] info: 	zh:ember: [STACK STATUS] Network up.
[2024-09-24 07:55:34] info: 	zh:ember: [INIT TC] Adapter network matches config.
[2024-09-24 07:55:34] info: 	zh:ember: [CONCENTRATOR] Started source route discovery. 1249ms until next broadcast.
[2024-09-24 07:55:34] info: 	z2m: zigbee-herdsman started (resumed)
[2024-09-24 07:55:34] info: 	z2m: Coordinator firmware version: '{"meta":{"build":0,"ezsp":13,"major":7,"minor":4,"patch":4,"revision":"7.4.4 [GA]","special":0,"type":170},"type":"EmberZNet"}'
[2024-09-24 07:55:34] info: 	z2m: Washing Machine Plug (0x00158d000ad7d587): ZNCZ12LM - Aqara Smart plug US (Router)
[2024-09-24 07:55:34] info: 	z2m: Dryer Plug (0x00158d000ada099b): ZNCZ12LM - Aqara Smart plug US (Router)
[2024-09-24 07:55:34] info: 	z2m: Deck Lights (0x54ef441000b3c576): WS-USC03 - Aqara Smart wall switch (with neutral, single rocker), US (Router)
[2024-09-24 07:55:34] info: 	z2m: Pergola Lights (0x54ef441000b3c63b): WS-USC03 - Aqara Smart wall switch (with neutral, single rocker), US (Router)
[2024-09-24 07:55:34] info: 	z2m: Office Outlet (0x00124b002e1d4b43): S40ZBTPB - SONOFF 15A Zigbee smart plug (Router)
[2024-09-24 07:55:34] info: 	z2m: Kitchen Outlet (0x00124b002dfddc0a): S40ZBTPB - SONOFF 15A Zigbee smart plug (Router)
[2024-09-24 07:55:34] info: 	z2m: Garage Plug (0x00124b002e1e2140): S40ZBTPB - SONOFF 15A Zigbee smart plug (Router)
[2024-09-24 07:55:34] info: 	z2m: Laundry Door Cabinet (0x00158d000abd7384): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
[2024-09-24 07:55:34] info: 	z2m: Reghan Bedroom Outlet (0x00124b002e1d4ecf): S40ZBTPB - SONOFF 15A Zigbee smart plug (Router)
[2024-09-24 07:55:34] info: 	z2m: Currently 9 devices are joined.
[2024-09-24 07:55:34] info: 	z2m: Zigbee: disabling joining new devices.
[2024-09-24 07:55:34] info: 	z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2024-09-24 07:55:34] info: 	z2m: Connected to MQTT server
[2024-09-24 07:55:34] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2024-09-24 07:55:34] info: 	z2m: Started frontend on port 8099
[2024-09-24 07:55:34] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Washing Machine Plug', payload '{"auto_off":null,"consumer_connected":null,"consumption":6.278104782104492,"current":null,"device_temperature":32,"energy":6.28,"led_disabled_night":null,"linkquality":232,"overload_protection":null,"power":1.72,"power_outage_count":9,"power_outage_memory":null,"state":"ON","update":{"installed_version":17,"latest_version":17,"state":"idle"},"update_available":false,"voltage":null}'
[2024-09-24 07:55:34] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Dryer Plug', payload '{"auto_off":null,"consumer_connected":null,"consumption":18.541215896606445,"current":null,"device_temperature":36,"energy":18.54,"led_disabled_night":null,"linkquality":228,"overload_protection":null,"power":1.47,"power_outage_count":12,"power_outage_memory":null,"state":"ON","update":{"installed_version":17,"latest_version":17,"state":"idle"},"update_available":false,"voltage":null}'
[2024-09-24 07:55:34] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Deck Lights', payload '{"action":null,"consumption":0.4036826193332672,"current":0,"device_temperature":24,"energy":0.4,"flip_indicator_light":null,"linkquality":244,"operation_mode":null,"power":0,"power_outage_count":13,"power_outage_memory":null,"state":"OFF","update":{"installed_version":31,"latest_version":31,"state":"idle"},"update_available":null,"voltage":120}'
[2024-09-24 07:55:34] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Pergola Lights', payload '{"action":null,"consumption":20.954710006713867,"current":0,"device_temperature":23,"energy":20.95,"flip_indicator_light":null,"linkquality":228,"operation_mode":null,"power":0,"power_outage_count":10,"power_outage_memory":null,"state":"OFF","update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null,"voltage":117}'
[2024-09-24 07:55:34] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Office Outlet', payload '{"linkquality":196,"state":"ON","update":{"installed_version":4352,"latest_version":4099,"state":"idle"},"update_available":false}'
[2024-09-24 07:55:34] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kitchen Outlet', payload '{"linkquality":220,"state":"OFF","update":{"installed_version":4352,"latest_version":4099,"state":"idle"},"update_available":false}'
[2024-09-24 07:55:34] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Garage Plug', payload '{"linkquality":232,"state":"ON","update":{"installed_version":4352,"latest_version":4099,"state":"idle"},"update_available":false}'
[2024-09-24 07:55:34] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Laundry Door Cabinet', payload '{"battery":100,"contact":false,"device_temperature":19,"linkquality":232,"power_outage_count":20,"trigger_count":0,"voltage":3025}'
[2024-09-24 07:55:34] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Reghan Bedroom Outlet', payload '{"linkquality":180,"state":"OFF","update":{"installed_version":4352,"latest_version":4099,"state":"idle"},"update_available":null}'
[2024-09-24 07:55:34] info: 	z2m: Zigbee2MQTT started!
[2024-09-24 07:55:39] info: 	z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0xb43522fffe2152a4/connection_state/config', payload '{"device":{"hw_version":"EmberZNet 7.4.4 [GA]","identifiers":["zigbee2mqtt_bridge_0xb43522fffe2152a4"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"1.40.1"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"1.40.1","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0xb43522fffe2152a4_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
[2024-09-24 07:55:41] info: 	z2m: Starting network scan (includeRoutes 'false')
[2024-09-24 07:55:58] error: 	z2m: Failed to execute LQI for 'Washing Machine Plug'
[2024-09-24 07:56:14] error: 	z2m: Failed to execute LQI for 'Dryer Plug'
[2024-09-24 07:56:31] error: 	z2m: Failed to execute LQI for 'Pergola Lights'
[2024-09-24 07:56:46] error: 	z2m: Failed to execute LQI for 'Office Outlet'
[2024-09-24 07:56:57] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Deck Lights', payload '{"action":null,"consumption":0.4036826193332672,"current":0,"device_temperature":24,"energy":0.4,"flip_indicator_light":null,"linkquality":92,"operation_mode":null,"power":0,"power_outage_count":13,"power_outage_memory":null,"state":"OFF","update":{"installed_version":31,"latest_version":31,"state":"idle"},"update_available":null,"voltage":120}'
[2024-09-24 07:57:23] error: 	z2m: Failed to execute LQI for 'Garage Plug'
[2024-09-24 07:57:39] error: 	z2m: Failed to execute LQI for 'Reghan Bedroom Outlet'
[2024-09-24 07:57:39] info: 	z2m: Network scan finished
[2024-09-24 07:57:39] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/networkmap', payload '{"data":{"routes":false,"type":"raw","value":{"links":[{"depth":15,"linkquality":88,"lqi":88,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002e1e2140","networkAddress":4354},"sourceIeeeAddr":"0x00124b002e1e2140","sourceNwkAddr":4354,"target":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"targetIeeeAddr":"0xb43522fffe2152a4"},{"depth":15,"linkquality":184,"lqi":184,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002e1d4b43","networkAddress":5557},"sourceIeeeAddr":"0x00124b002e1d4b43","sourceNwkAddr":5557,"target":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"targetIeeeAddr":"0xb43522fffe2152a4"},{"depth":15,"linkquality":240,"lqi":240,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00158d000ad7d587","networkAddress":11708},"sourceIeeeAddr":"0x00158d000ad7d587","sourceNwkAddr":11708,"target":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"targetIeeeAddr":"0xb43522fffe2152a4"},{"depth":15,"linkquality":196,"lqi":196,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002e1d4ecf","networkAddress":16438},"sourceIeeeAddr":"0x00124b002e1d4ecf","sourceNwkAddr":16438,"target":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"targetIeeeAddr":"0xb43522fffe2152a4"},{"depth":15,"linkquality":224,"lqi":224,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00158d000ada099b","networkAddress":17589},"sourceIeeeAddr":"0x00158d000ada099b","sourceNwkAddr":17589,"target":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"targetIeeeAddr":"0xb43522fffe2152a4"},{"depth":0,"linkquality":51,"lqi":51,"relationship":0,"routes":[],"source":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"sourceIeeeAddr":"0xb43522fffe2152a4","sourceNwkAddr":0,"target":{"ieeeAddr":"0x54ef441000b3c576","networkAddress":3580},"targetIeeeAddr":"0x54ef441000b3c576"},{"depth":1,"linkquality":118,"lqi":118,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"sourceIeeeAddr":"0x00124b002dfddc0a","sourceNwkAddr":14590,"target":{"ieeeAddr":"0x54ef441000b3c576","networkAddress":3580},"targetIeeeAddr":"0x54ef441000b3c576"},{"depth":255,"linkquality":44,"lqi":44,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00158d000ada099b","networkAddress":17589},"sourceIeeeAddr":"0x00158d000ada099b","sourceNwkAddr":17589,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":55,"lqi":55,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00158d000ad7d587","networkAddress":11708},"sourceIeeeAddr":"0x00158d000ad7d587","sourceNwkAddr":11708,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":59,"lqi":59,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x54ef441000b3c576","networkAddress":3580},"sourceIeeeAddr":"0x54ef441000b3c576","sourceNwkAddr":3580,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":23,"lqi":23,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002e1e2140","networkAddress":4354},"sourceIeeeAddr":"0x00124b002e1e2140","sourceNwkAddr":4354,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":0,"lqi":0,"relationship":2,"routes":[],"source":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"sourceIeeeAddr":"0xb43522fffe2152a4","sourceNwkAddr":0,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":0,"lqi":0,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002e1d4b43","networkAddress":5557},"sourceIeeeAddr":"0x00124b002e1d4b43","sourceNwkAddr":5557,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":0,"lqi":0,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002e1d4ecf","networkAddress":16438},"sourceIeeeAddr":"0x00124b002e1d4ecf","sourceNwkAddr":16438,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":0,"lqi":0,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00158d000abd7384","networkAddress":27327},"sourceIeeeAddr":"0x00158d000abd7384","sourceNwkAddr":27327,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"}],"nodes":[{"definition":null,"failed":[],"friendlyName":"Coordinator","ieeeAddr":"0xb43522fffe2152a4","lastSeen":1722360241288,"networkAddress":0,"type":"Coordinator"},{"definition":{"description":"Smart plug US","model":"ZNCZ12LM","supports":"switch (state), power, energy, device_temperature, voltage, current, consumer_connected, led_disabled_night, power_outage_memory, auto_off, overload_protection, linkquality","vendor":"Aqara"},"failed":["lqi"],"friendlyName":"Washing Machine Plug","ieeeAddr":"0x00158d000ad7d587","lastSeen":1724785029268,"manufacturerName":"LUMI","modelID":"lumi.plug.maus01","networkAddress":48876,"type":"Router"},{"definition":{"description":"Smart plug US","model":"ZNCZ12LM","supports":"switch (state), power, energy, device_temperature, voltage, current, consumer_connected, led_disabled_night, power_outage_memory, auto_off, overload_protection, linkquality","vendor":"Aqara"},"failed":["lqi"],"friendlyName":"Dryer Plug","ieeeAddr":"0x00158d000ada099b","lastSeen":1724785026826,"manufacturerName":"LUMI","modelID":"lumi.plug.maus01","networkAddress":7088,"type":"Router"},{"definition":{"description":"Smart wall switch (with neutral, single rocker), US","model":"WS-USC03","supports":"switch (state), flip_indicator_light, power_outage_count, device_temperature, power, energy, voltage, power_outage_memory, operation_mode, action, linkquality","vendor":"Aqara"},"failed":[],"friendlyName":"Deck Lights","ieeeAddr":"0x54ef441000b3c576","lastSeen":1727179017203,"manufacturerName":"LUMI","modelID":"lumi.switch.b1naus01","networkAddress":3580,"type":"Router"},{"definition":{"description":"Smart wall switch (with neutral, single rocker), US","model":"WS-USC03","supports":"switch (state), flip_indicator_light, power_outage_count, device_temperature, power, energy, voltage, power_outage_memory, operation_mode, action, linkquality","vendor":"Aqara"},"failed":["lqi"],"friendlyName":"Pergola Lights","ieeeAddr":"0x54ef441000b3c63b","lastSeen":1725966444022,"manufacturerName":"LUMI","modelID":"lumi.switch.b1naus01","networkAddress":25271,"type":"Router"},{"definition":{"description":"15A Zigbee smart plug","model":"S40ZBTPB","supports":"switch (state), linkquality","vendor":"SONOFF"},"failed":["lqi"],"friendlyName":"Office Outlet","ieeeAddr":"0x00124b002e1d4b43","lastSeen":1724770127679,"manufacturerName":"SONOFF","modelID":"S40LITE","networkAddress":31177,"type":"Router"},{"definition":{"description":"15A Zigbee smart plug","model":"S40ZBTPB","supports":"switch (state), linkquality","vendor":"SONOFF"},"failed":[],"friendlyName":"Kitchen Outlet","ieeeAddr":"0x00124b002dfddc0a","lastSeen":1727170195367,"manufacturerName":"SONOFF","modelID":"S40LITE","networkAddress":14590,"type":"Router"},{"definition":{"description":"15A Zigbee smart plug","model":"S40ZBTPB","supports":"switch (state), linkquality","vendor":"SONOFF"},"failed":["lqi"],"friendlyName":"Garage Plug","ieeeAddr":"0x00124b002e1e2140","lastSeen":1724774658821,"manufacturerName":"SONOFF","modelID":"S40LITE","networkAddress":10950,"type":"Router"},{"definition":{"description":"Door and window sensor","model":"MCCGQ11LM","supports":"battery, contact, device_temperature, voltage, power_outage_count, trigger_count, linkquality","vendor":"Aqara"},"friendlyName":"Laundry Door Cabinet","ieeeAddr":"0x00158d000abd7384","lastSeen":1727176125432,"manufacturerName":"LUMI","modelID":"lumi.sensor_magnet.aq2","networkAddress":27327,"type":"EndDevice"},{"definition":{"description":"15A Zigbee smart plug","model":"S40ZBTPB","supports":"switch (state), linkquality","vendor":"SONOFF"},"failed":["lqi"],"friendlyName":"Reghan Bedroom Outlet","ieeeAddr":"0x00124b002e1d4ecf","lastSeen":1724785291183,"manufacturerName":"SONOFF","modelID":"S40LITE","networkAddress":35587,"type":"Router"}]}},"status":"ok","transaction":"zh01i-1"}'
[2024-09-24 07:58:27] info: 	zh:ember:ezsp: Received network/route error ROUTE_ERROR_MANY_TO_ONE_ROUTE_FAILURE for "63638".
[2024-09-24 07:58:48] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Laundry Door Cabinet', payload '{"battery":100,"contact":false,"device_temperature":20,"linkquality":240,"power_outage_count":20,"trigger_count":0,"voltage":3025}'
[2024-09-24 08:03:15] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Deck Lights', payload '{"action":null,"consumption":0.4036826193332672,"current":0,"device_temperature":24,"energy":0.4,"flip_indicator_light":null,"linkquality":232,"operation_mode":null,"power":0,"power_outage_count":13,"power_outage_memory":null,"state":"OFF","update":{"installed_version":31,"latest_version":31,"state":"idle"},"update_available":null,"voltage":120}'
[2024-09-24 08:06:10] info: 	z2m: Starting network scan (includeRoutes 'false')
[2024-09-24 08:06:27] error: 	z2m: Failed to execute LQI for 'Washing Machine Plug'
[2024-09-24 08:06:42] error: 	z2m: Failed to execute LQI for 'Dryer Plug'
[2024-09-24 08:06:59] error: 	z2m: Failed to execute LQI for 'Pergola Lights'
[2024-09-24 08:07:14] error: 	z2m: Failed to execute LQI for 'Office Outlet'
[2024-09-24 08:07:31] error: 	z2m: Failed to execute LQI for 'Garage Plug'
[2024-09-24 08:07:47] error: 	z2m: Failed to execute LQI for 'Reghan Bedroom Outlet'
[2024-09-24 08:07:47] info: 	z2m: Network scan finished
[2024-09-24 08:07:47] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/networkmap', payload '{"data":{"routes":false,"type":"raw","value":{"links":[{"depth":15,"linkquality":92,"lqi":92,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002e1e2140","networkAddress":4354},"sourceIeeeAddr":"0x00124b002e1e2140","sourceNwkAddr":4354,"target":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"targetIeeeAddr":"0xb43522fffe2152a4"},{"depth":15,"linkquality":182,"lqi":182,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002e1d4b43","networkAddress":5557},"sourceIeeeAddr":"0x00124b002e1d4b43","sourceNwkAddr":5557,"target":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"targetIeeeAddr":"0xb43522fffe2152a4"},{"depth":15,"linkquality":241,"lqi":241,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00158d000ad7d587","networkAddress":11708},"sourceIeeeAddr":"0x00158d000ad7d587","sourceNwkAddr":11708,"target":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"targetIeeeAddr":"0xb43522fffe2152a4"},{"depth":15,"linkquality":88,"lqi":88,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"sourceIeeeAddr":"0x00124b002dfddc0a","sourceNwkAddr":14590,"target":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"targetIeeeAddr":"0xb43522fffe2152a4"},{"depth":15,"linkquality":196,"lqi":196,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002e1d4ecf","networkAddress":16438},"sourceIeeeAddr":"0x00124b002e1d4ecf","sourceNwkAddr":16438,"target":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"targetIeeeAddr":"0xb43522fffe2152a4"},{"depth":15,"linkquality":231,"lqi":231,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00158d000ada099b","networkAddress":17589},"sourceIeeeAddr":"0x00158d000ada099b","sourceNwkAddr":17589,"target":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"targetIeeeAddr":"0xb43522fffe2152a4"},{"depth":1,"linkquality":119,"lqi":119,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"sourceIeeeAddr":"0x00124b002dfddc0a","sourceNwkAddr":14590,"target":{"ieeeAddr":"0x54ef441000b3c576","networkAddress":3580},"targetIeeeAddr":"0x54ef441000b3c576"},{"depth":255,"linkquality":46,"lqi":46,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00158d000ada099b","networkAddress":17589},"sourceIeeeAddr":"0x00158d000ada099b","sourceNwkAddr":17589,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":55,"lqi":55,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00158d000ad7d587","networkAddress":11708},"sourceIeeeAddr":"0x00158d000ad7d587","sourceNwkAddr":11708,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":56,"lqi":56,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x54ef441000b3c576","networkAddress":3580},"sourceIeeeAddr":"0x54ef441000b3c576","sourceNwkAddr":3580,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":24,"lqi":24,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002e1e2140","networkAddress":4354},"sourceIeeeAddr":"0x00124b002e1e2140","sourceNwkAddr":4354,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":0,"lqi":0,"relationship":2,"routes":[],"source":{"ieeeAddr":"0xb43522fffe2152a4","networkAddress":0},"sourceIeeeAddr":"0xb43522fffe2152a4","sourceNwkAddr":0,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":0,"lqi":0,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002e1d4b43","networkAddress":5557},"sourceIeeeAddr":"0x00124b002e1d4b43","sourceNwkAddr":5557,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":0,"lqi":0,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00124b002e1d4ecf","networkAddress":16438},"sourceIeeeAddr":"0x00124b002e1d4ecf","sourceNwkAddr":16438,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"},{"depth":255,"linkquality":0,"lqi":0,"relationship":2,"routes":[],"source":{"ieeeAddr":"0x00158d000abd7384","networkAddress":27327},"sourceIeeeAddr":"0x00158d000abd7384","sourceNwkAddr":27327,"target":{"ieeeAddr":"0x00124b002dfddc0a","networkAddress":14590},"targetIeeeAddr":"0x00124b002dfddc0a"}],"nodes":[{"definition":null,"failed":[],"friendlyName":"Coordinator","ieeeAddr":"0xb43522fffe2152a4","lastSeen":1722360241288,"networkAddress":0,"type":"Coordinator"},{"definition":{"description":"Smart plug US","model":"ZNCZ12LM","supports":"switch (state), power, energy, device_temperature, voltage, current, consumer_connected, led_disabled_night, power_outage_memory, auto_off, overload_protection, linkquality","vendor":"Aqara"},"failed":["lqi"],"friendlyName":"Washing Machine Plug","ieeeAddr":"0x00158d000ad7d587","lastSeen":1724785029268,"manufacturerName":"LUMI","modelID":"lumi.plug.maus01","networkAddress":48876,"type":"Router"},{"definition":{"description":"Smart plug US","model":"ZNCZ12LM","supports":"switch (state), power, energy, device_temperature, voltage, current, consumer_connected, led_disabled_night, power_outage_memory, auto_off, overload_protection, linkquality","vendor":"Aqara"},"failed":["lqi"],"friendlyName":"Dryer Plug","ieeeAddr":"0x00158d000ada099b","lastSeen":1724785026826,"manufacturerName":"LUMI","modelID":"lumi.plug.maus01","networkAddress":7088,"type":"Router"},{"definition":{"description":"Smart wall switch (with neutral, single rocker), US","model":"WS-USC03","supports":"switch (state), flip_indicator_light, power_outage_count, device_temperature, power, energy, voltage, power_outage_memory, operation_mode, action, linkquality","vendor":"Aqara"},"failed":[],"friendlyName":"Deck Lights","ieeeAddr":"0x54ef441000b3c576","lastSeen":1727179395259,"manufacturerName":"LUMI","modelID":"lumi.switch.b1naus01","networkAddress":3580,"type":"Router"},{"definition":{"description":"Smart wall switch (with neutral, single rocker), US","model":"WS-USC03","supports":"switch (state), flip_indicator_light, power_outage_count, device_temperature, power, energy, voltage, power_outage_memory, operation_mode, action, linkquality","vendor":"Aqara"},"failed":["lqi"],"friendlyName":"Pergola Lights","ieeeAddr":"0x54ef441000b3c63b","lastSeen":1725966444022,"manufacturerName":"LUMI","modelID":"lumi.switch.b1naus01","networkAddress":25271,"type":"Router"},{"definition":{"description":"15A Zigbee smart plug","model":"S40ZBTPB","supports":"switch (state), linkquality","vendor":"SONOFF"},"failed":["lqi"],"friendlyName":"Office Outlet","ieeeAddr":"0x00124b002e1d4b43","lastSeen":1724770127679,"manufacturerName":"SONOFF","modelID":"S40LITE","networkAddress":31177,"type":"Router"},{"definition":{"description":"15A Zigbee smart plug","model":"S40ZBTPB","supports":"switch (state), linkquality","vendor":"SONOFF"},"failed":[],"friendlyName":"Kitchen Outlet","ieeeAddr":"0x00124b002dfddc0a","lastSeen":1727170195367,"manufacturerName":"SONOFF","modelID":"S40LITE","networkAddress":14590,"type":"Router"},{"definition":{"description":"15A Zigbee smart plug","model":"S40ZBTPB","supports":"switch (state), linkquality","vendor":"SONOFF"},"failed":["lqi"],"friendlyName":"Garage Plug","ieeeAddr":"0x00124b002e1e2140","lastSeen":1724774658821,"manufacturerName":"SONOFF","modelID":"S40LITE","networkAddress":10950,"type":"Router"},{"definition":{"description":"Door and window sensor","model":"MCCGQ11LM","supports":"battery, contact, device_temperature, voltage, power_outage_count, trigger_count, linkquality","vendor":"Aqara"},"friendlyName":"Laundry Door Cabinet","ieeeAddr":"0x00158d000abd7384","lastSeen":1727179128897,"manufacturerName":"LUMI","modelID":"lumi.sensor_magnet.aq2","networkAddress":27327,"type":"EndDevice"},{"definition":{"description":"15A Zigbee smart plug","model":"S40ZBTPB","supports":"switch (state), linkquality","vendor":"SONOFF"},"failed":["lqi"],"friendlyName":"Reghan Bedroom Outlet","ieeeAddr":"0x00124b002e1d4ecf","lastSeen":1724785291183,"manufacturerName":"SONOFF","modelID":"S40LITE","networkAddress":35587,"type":"Router"}]}},"status":"ok","transaction":"zh01i-2"}'
[2024-09-24 08:08:11] info: 	z2m: Configuring 'Pergola Lights'
[2024-09-24 08:08:11] info: 	z2m: Successfully configured 'Pergola Lights'
[2024-09-24 08:08:11] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/device/configure', payload '{"data":{"id":"Pergola Lights"},"status":"ok","transaction":"zh01i-3"}'
[2024-09-24 08:08:33] info: 	z2m: Interviewing 'Pergola Lights'
[2024-09-24 08:08:38] info: 	z2m: Successfully interviewed 'Pergola Lights'
[2024-09-24 08:08:38] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/device/interview', payload '{"data":{"id":"Pergola Lights"},"status":"ok","transaction":"zh01i-4"}'
[2024-09-24 08:09:03] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Deck Lights', payload '{"action":null,"consumption":0.4036826193332672,"current":0,"device_temperature":24,"energy":0.4,"flip_indicator_light":null,"linkquality":92,"operation_mode":null,"power":0,"power_outage_count":13,"power_outage_memory":null,"state":"OFF","update":{"installed_version":31,"latest_version":31,"state":"idle"},"update_available":null,"voltage":120}'
[2024-09-24 08:09:05] error: 	z2m: Publish 'set' 'state' to 'Dryer Plug' failed: 'Error: ZCL command 0x00158d000ada099b/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for {"profileId":260,"clusterId":6,"sourceEndpoint":1,"destinationEndpoint":1,"options":4160,"groupId":0,"sequence":177})'
[2024-09-24 08:09:10] error: 	z2m: Publish 'set' 'state' to 'Dryer Plug' failed: 'Error: ZCL command 0x00158d000ada099b/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for {"profileId":260,"clusterId":6,"sourceEndpoint":1,"destinationEndpoint":1,"options":4160,"groupId":0,"sequence":178})'
[2024-09-24 08:10:54] error: 	z2m: Publish 'set' 'state' to 'Garage Plug' failed: 'Error: ZCL command 0x00124b002e1e2140/1 genOnOff.off({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for {"profileId":260,"clusterId":6,"sourceEndpoint":1,"destinationEndpoint":1,"options":4160,"groupId":0,"sequence":179})'
[2024-09-24 08:11:05] error: 	z2m: Publish 'set' 'state' to 'Garage Plug' failed: 'Error: ZCL command 0x00124b002e1e2140/1 genOnOff.on({}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Delivery failed for {"profileId":260,"clusterId":6,"sourceEndpoint":1,"destinationEndpoint":1,"options":4160,"groupId":0,"sequence":180})
