Hello community,
I am new to HA but got a lot of help and good ideas from here to move over from my Homematic installation to HA.
With over 200 devices, or channels, in Homematic and 4 persons in my house, I allways get into trouble with this silly 1% duty cycle limmitation. And yes, I already optimized all my programs so they only “send” something when a something should change. But anyway, with that lot devices and 4 persons there is much movement in the house and so the communication between the Homematic devices and their central station.
So I decided to move over to HA with Zigbee. Since Zigbee is a mesh like network and doesn’t has any duty cycle, I hope the communication gets better.
First I moved my new Hue lamps to HA using a Hue Bridge. This works very good with no problems.
Now I want to add some other devices that Philips doesn’t offer, like duo wall switches. I tried the Aeotec Pico Duo Switch but I couldn’t connect it to the Philips Hue Bridge.
I don’t want to give up my Philips Hue Bridges cause I use the HDMI Sync Box on 2 TVs. If its needed, I would by another Zigbee hub, but which one?
I want to be as future proof as possible. My HA installation is running on a synology disk station in the basement, so please no USB stick solution for Zigbee. A network device would be better.
Also, I need a suggestion for a good device supplier. Thought Aeotec would be a good supplier. But it says “Zigbee 3.0 works”, but it doesn’t work. Anyway, I would like to use switch modules only with clamp ports, no screws. This was the reason I tried the Aeotec ones. Are there any other out there? Homematic also got allways clamp connectors. Sadly the Shelly ones all have screws
Maybe someone can share their exprience with me and some suggestions. Also if it’s a good idea to keep the Hue bridges only for the 2 TVs and move all the other lamps to another Zigbee hub. Is there any hub that can also update Hue lamps?
Thanks and regards,
Benny
