Zigbee not 100% reliable?
I’m using ZHA with a Conbee II stick. About one in 50 times, my Philips Hue bulbs are not turning on/off (triggered by automation) even though the logs show that they were turned on/off. This even happens with a bulb that is no more than 7 feet from my conbee II stick (which is plugged into my Raspberry Pi 4 with a USB extension cable).
Any idea what the issue could be? Is there any way to verify if the Conbee II stick actually sent the on/off command?
Here is some more info for clarification.
The first picture shows a screenshot of the automation log that turns on my office lamp. The automation got triggered by a motion sensor at 03:09:04 and executed a generic ”turn on" command for the office lamp. However, if you look at the logs for the office lamp, you can see that the lamp itself was not turned on at 03.09:04, even though according to the log of the automation it was. (This happens maybe 1 out of 50 times).
