Just a simple question (hopefully).
Why is, on the HA Yellow, the Zigbee module, called: Yellow?
On the Raspberry install, it was called ZHA, but now it is called: Yellow.
Is there a reason and for Quirks, should I refer to ZHA or to Yellow?
No difference, just a partnership relationship IIRC
If auto recognized, it is usually named after the adapter if it recognizes it. The integration is still ZHA, as noted in the subtitle. I think if manually added it may show as some variant of ZHA.
For instance mine is: . It is stlll ZHA, there is no “Sonoff Zigbee” integration.
[Solved]
Thanks for your info.
I found out that for the Quirks “ZHA” is indeed that correct identifier and not Yellow.
Willem-Bram
