aelsharawi:
460800
2023-04-14 21:42:05 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'un\r\n3. ebl info\r'
2023-04-14 21:42:05 core-silabs-flasher universal_silabs_flasher.cpc[158] WARNING Failed to parse buffer bytearray(b'\r'): ValueError('Invalid flag')
2023-04-14 21:42:05 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\nBL > \x00\r\nGecko B'
2023-04-14 21:42:05 core-silabs-flasher universal_silabs_flasher.cpc[158] WARNING Failed to parse buffer bytearray(b'B'): ValueError('Invalid flag')
2023-04-14 21:42:06 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2023-04-14 21:42:06 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2023-04-14 21:42:06 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2023-04-14 21:42:07 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2023-04-14 21:42:07 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2023-04-14 21:42:07 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2023-04-14 21:42:08 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2023-04-14 21:42:08 core-silabs-flasher universal_silabs_flasher.flasher[158] INFO Probing ApplicationType.CPC at 230400 baud
2023-04-14 21:42:08 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.cpc.CPCProtocol object at 0x7fb7fcd600>, Serial<id=0x7fb7f3ba30, open=True>(port='/dev/ttyAMA1', baudrate=230400, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2023-04-14 21:42:08 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2023-04-14 21:42:08 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2023-04-14 21:42:08 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\xe6\x80\x98\x80~\x98f\x9e\x1e\x9e\x9e\x9e\xfe\x9e\x00\x18'
2023-04-14 21:42:08 core-silabs-flasher universal_silabs_flasher.cpc[158] WARNING Failed to parse buffer bytearray(b'\x18'): ValueError('Invalid flag')
2023-04-14 21:42:08 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x18\x06`\x86~\x18\x18\x86\x00\x18\xe0\x18\x86\x00\x98\xe0'
2023-04-14 21:42:08 core-silabs-flasher universal_silabs_flasher.cpc[158] WARNING Failed to parse buffer bytearray(b'\xe0'): ValueError('Invalid flag')
2023-04-14 21:42:08 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x98\x1e\x18\x06fx\x86\x86\x00\x98\xe6\x06\xf8\x06\x9e\xfe\x9e\x06\x9e`\x9e\x00\x98x\x18\x9e\xe0\x9e\xe6\x80\x98\x80\x18\x18\x86\x00\x18\xf8f~\xf8\x9e\xe6\x80\x98\x80\x1e\x18'
2023-04-14 21:42:08 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x9e\xe6\x80\x98\x80\x18\x98\xe0\x98\x00\x18\x18\x80\x18\x00'
2023-04-14 21:42:08 core-silabs-flasher universal_silabs_flasher.cpc[158] WARNING Failed to parse buffer bytearray(b'\x00'): ValueError('Invalid flag')
2023-04-14 21:42:09 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 1 of 4)
2023-04-14 21:42:09 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2023-04-14 21:42:09 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2023-04-14 21:42:10 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 2 of 4)
2023-04-14 21:42:10 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2023-04-14 21:42:10 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2023-04-14 21:42:11 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 3 of 4)
2023-04-14 21:42:11 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Sending frame CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b'')))
2023-04-14 21:42:11 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Sending data b'\x14\x00\n\x00\xc4U\xd3\x02\x00\x04\x00\x03\x00\x00\x00\xdb\x12'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.cpc[158] DEBUG Failed to send CPCTransportFrame(endpoint=<EndpointId.SYSTEM: 0>, control=196, payload=UnnumberedFrame(command_id=<UnnumberedFrameCommandId.PROP_VALUE_GET: 2>, command_seq=0, payload=PropertyCommand(property_id=<PropertyId.SECONDARY_CPC_VERSION: 3>, value=b''))), trying again in 0.10s (attempt 4 of 4)
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.flasher[158] INFO Probing ApplicationType.SPINEL at 460800 baud
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <universal_silabs_flasher.spinel.SpinelProtocol object at 0x7fb7fcd570>, Serial<id=0x7fb7fcd600, open=True>(port='/dev/ttyAMA1', baudrate=460800, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.spinel[158] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Sending data b'~\x83\x02\x02\xe65~'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\xfex\xfe\xf8x\x00\x80\x80\x00x\xfe\xf8x\xfe\xf8'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\x00\xf8x\x00\xf8x\xfe\xf8x\x1e\x00x\x00\x80x'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x1e\x80x\xe0\x80x\x00\x80\x80\xf8x\xe0\x80\x80\x80x'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\xe0\x00\x80\x00\x80\x80x\xe0\x00\x80x\x00\x80x\xfe\x00\x80x\x00x\x00\x80\x80x\xe0\x00\x80x\x1ex\x00x'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x00\xf8x\xfe\xf8x\x1e\x00x\x00\x80x\x00\x80\xf8\x80'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\xe0\x00x\x00\xf8x\x1e\x00\x80x\x00\x80\x80\x80\x80x\xe0\x00\x80\x80\x80x\x1e\xf8x\xe0\xf8x\x1e\x00\x80'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\x00\xf8\x80\x80\x80x\xe0\x00\x80x\x1e\xf8x\xe0\x00x\x00\xf8x\x00\x80x\xe0\xf8x\xe0\xf8x\xe0\x80x'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\xfe\xf8x\x1e\x00\x80x\x00\x80\x00x\x00\x80x\x00\x80\x80\x80\x00\x80\x00'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\xfe\x00\x80x\x00\xf8\x00x\x1e\x80x\xfe\x00x\xfex\xfex\xfe\xf8x\x00\x80\x80\x00x\xfe\xf8x\xfe\xf8'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\x00\xf8x\x00\xf8x\xfe\xf8x\x1e\x00x\x00\x80x\x1e\x80x\xe0\x80x\x00\x80\x80\xf8x\xe0\x80\x80\x80x\xe0'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x00\x80\x00\x80\x80x\xe0\x00\x80x\x00\x80x\xfe\x00\x80'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\x00x\x00\x80\x80x\xe0\x00\x80x\x1ex\x00x\x00\xf8x\xfe\xf8x\x1e\x00x\x00\x80x\x00\x80\xf8\x80x'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\xe0\x00x\x00\xf8x\x1e\x00\x80x\x00\x80\x80\x80\x80x\xe0\x00\x80\x80\x80x\x1e\xf8x\xe0\xf8x\x1e\x00\x80x'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x00\xf8\x80\x80\x80x\xe0\x00\x80x\x1e\xf8x\xe0\x00x'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x00\xf8x\x00\x80x\xe0\xf8x\xe0\xf8x\xe0\x80x\xfe\xf8x\x1e\x00\x80x\x00\x80\x00x\x00\x80x\x00\x80\x80'
2023-04-14 21:42:12 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x80\x00\x80\x00'
2023-04-14 21:42:13 core-silabs-flasher universal_silabs_flasher.spinel[158] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 1 of 4)
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.spinel[158] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Sending data b'~\x83\x02\x02\xe65~'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\xfex\xfe\xf8x\x00\x80\x80\x00x\xfe\xf8x\xfe\xf8'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\x00\xf8x\x00\xf8x\xfe\xf8x\x1e\x00x\x00\x80x'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x1e\x80x\xe0\x80x\x00\x80\x80\xf8x\xe0\x80\x80\x80x'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\xe0\x00\x80\x00\x80\x80x\xe0\x00\x80x\x00\x80x\xfe\x00'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x80x\x00x\x00\x80\x80x\xe0\x00\x80x\x1ex\x00x\x00\xf8x\xfe\xf8x\x1e\x00x\x00\x80x\x00\x80\xf8\x80'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\xe0\x00x\x00\xf8x\x1e\x00\x80x\x00\x80\x80\x80\x80'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\xe0\x00\x80\x80\x80x\x1e\xf8x\xe0\xf8x\x1e\x00\x80'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\x00\xf8\x80\x80\x80x\xe0\x00\x80x\x1e\xf8x\xe0\x00'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\x00\xf8x\x00\x80x\xe0\xf8x\xe0\xf8x\xe0\x80x'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\xfe\xf8x\x1e\x00\x80x\x00\x80\x00x\x00\x80x\x00\x80'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x80\x80\x00\x80\x00'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\xfe\x00\x80x\x00\xf8\x00x\x1e\x80x\xfe\x00x\xfe'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\xfex\xfe\xf8x\x00\x80\x80\x00x\xfe\xf8x\xfe\xf8x\x00\xf8x\x00\xf8x\xfe\xf8x\x1e\x00x\x00\x80x'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\xe0\x00\x80\x00\x80\x80x\xe0\x00\x80x\x00\x80x\xfe\x00\x80x\x00x\x00\x80\x80x\xe0\x00\x80x\x1ex\x00x'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x00\xf8x\xfe\xf8x\x1e\x00x\x00\x80x\x00\x80\xf8\x80x\xe0\x00x\x00\xf8x\x1e\x00\x80x\x00\x80\x80\x80\x80'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\x00\xf8\x80\x80\x80x\xe0\x00\x80x\x1e\xf8x\xe0\x00x\x00\xf8x\x00\x80x\xe0\xf8x\xe0\xf8x\xe0\x80x'
2023-04-14 21:42:14 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\xfe\xf8x\x1e\x00\x80x\x00\x80\x00x\x00\x80x\x00\x80\x80\x80\x00\x80\x00'
2023-04-14 21:42:15 core-silabs-flasher universal_silabs_flasher.spinel[158] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 2 of 4)
2023-04-14 21:42:15 core-silabs-flasher universal_silabs_flasher.spinel[158] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2023-04-14 21:42:15 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Sending data b'~\x83\x02\x02\xe65~'
2023-04-14 21:42:15 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\xfe\x00\x80x\x00\xf8\x00x\x1e\x80x\xfe\x00x\xfe'
2023-04-14 21:42:15 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\x00\xf8x\x00\xf8x\xfe\xf8x\x1e\x00x\x00\x80x'
2023-04-14 21:42:15 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x1e\x80x\xe0\x80x\x00\x80\x80\xf8x\xe0\x80\x80\x80x\xe0\x00\x80\x00\x80\x80x\xe0\x00\x80x\x00\x80x\xfe\x00\x80x\x00x\x00\x80\x80x\xe0\x00\x80x\x1ex\x00x'
2023-04-14 21:42:15 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'\x00\xf8x\xfe\xf8x\x1e\x00x\x00\x80x\x00\x80\xf8\x80'
2023-04-14 21:42:15 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Received data b'x\xe0\x00x\x00\xf8x\x1e\x00\x80x\x00\x80\x80\x80\x80x\xe0\x00\x80\x80\x80x\x1e\xf8x\xe0\xf8x\x1e\x00\x80x\x00\xf8\x80\x80\x80x\xe0\x00\x80x\x1e\xf8x\xe0\x00'
2023-04-14 21:42:16 core-silabs-flasher universal_silabs_flasher.spinel[158] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 3 of 4)
2023-04-14 21:42:16 core-silabs-flasher universal_silabs_flasher.spinel[158] DEBUG Sending frame SpinelFrame(header=SpinelHeader(transaction_id=3, network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02')
2023-04-14 21:42:16 core-silabs-flasher universal_silabs_flasher.common[158] DEBUG Sending data b'~\x83\x02\x02\xe65~'
2023-04-14 21:42:17 core-silabs-flasher universal_silabs_flasher.spinel[158] DEBUG Failed to send SpinelFrame(header=SpinelHeader(network_link_id=0, flag=2), command_id=<CommandID.PROP_VALUE_GET: 2>, data=b'\x02'), trying again in 0.10s (attempt 4 of 4)
Error: Failed to probe running application type
[21:42:17] INFO: universal-silabs-flasher-up script exited with code 1
s6-rc: warning: unable to start service universal-silabs-flasher: command exited 1
s6-rc: info: service banner: stopping
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
