I am searching for a Wifi or Zigbee dimmer switch for a room that only has one wall switch; neutral is present. I have a Shelly Dimmer 2 however, there is not enough space behind the switch to mount it. The dimmer should work with LED (3 X 12W on same switch) and take the 230V & 50Hz supply.
I see some Moes (TuYa) products that fit the description, but not sure if they work with HA. Also, would be nice if it can run locally.
I have a few Shelly dimmer and one Moes dimmer and it works fine with the Tuya integration, however, I believe the Shelly’s dimmer is smaller than the Moes one or, at maximum, at similar size. And between those I won’t think twice about going with Shelly as the local integration works way smoother.
I hear you, but the problem is that behind the switch it’s full of cables and there is no space for the Shelly Dimmer. That’s why I’m on a lookout for “all-in-one”, like this: BSEED Dimmer Wall Switch - Amazon.de with depth of 25mm.
