I purchased a USB zigbee adaptor: usb-Texas_Instruments_TI_CC2531_USB_CDC and a zigbee radiator valve: zhaquirks.tuya.ts0601_trv
I then installed the Zigbee integration in HA which recognises the controller and the controller recognises the TRV after pairing.
In the Loveday dashboard, I can add the card for the TRV and change the target temperature BUT I can not do that in an automation as I only seem to be able to set on-off, Mode but not the target temperature as that option is not given. What I would like to do is set that target temperature to e.g. 21 and the valve opens / closes based on the temperature in the room.
Reading up on this on this forum people mention zigbee2mqtt so I tried to install that but it fails to start. My questions:
Do I need both the Zigbee integration AND Zigbee2mqtt or do I only need one of them?
Any idea why I can’t set the target temperature in my automation? Do I need to change something in the TRV configuration?
Thanks, @mobile.andrew.jones. That clears that up but leaves the second question. Is the fact that I can’t set a heat point in the TRV down to the TRV or is it down to my choice of ZHA versus Zigbee2MQTT?
Thanks, @maxym but, I don’t believe I get as far as being able to create a bug In the action section, I select the device and the only actions I can select are:
Turn On_Off
Toggle On_Off
Change HVAC Mode
Change Preset
That’s it… I can’t set the target temperature.
There’s more than just device actions. Your climate entity supports far more in the way of service calls, such as the climate.set_temperature service call.
Device triggers are just wrappers for normal triggers, same for conditions, and the same for actions. Usually in fact the device side of things is a subset of what’s possible.
They’re convenient for those that don’t take the time to dive into the documentation, but so far not even close to complete replacements.
