### What happened?
When I use the device they shut down suddenly. This happens …maybe once every one or two days. Don't know if it is a Z2M issue or a problem with the plug.
I have four of them, all have the same problem.
I made an automation to power the device on automatically but that cannot be the solution :)
![Schermafbeelding 2022-02-28 om 11 35 22](https://user-images.githubusercontent.com/39917461/155968838-8ec51ea7-16e8-4087-a69c-0fddab712e2b.png)
### What did you expect to happen?
The plug just stays on.
### How to reproduce it (minimal and precise)
I don't know. Just power on the device and wait.
### Zigbee2MQTT version
1.23.0-dev commit
### Adapter firmware version
20211217
### Adapter
zzh
### Debug log
`debug 2022-02-28 10:58:30: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
info 2022-02-28 10:58:30: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0.36,"energy":2.51,"indicator_mode":null,"linkquality":47,"power":79,"power_outage_memory":"on","state":"OFF","update":{"state":null},"update_available":null,"voltage":238}'
info 2022-02-28 10:58:30: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0.36,"energy":2.51,"indicator_mode":null,"linkquality":65,"power":79,"power_outage_memory":"on","state":"OFF","update":{"state":null},"update_available":null,"voltage":238}'
debug 2022-02-28 10:58:30: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'manuSpecificTuya_3', data '{"53249":4}' from endpoint 1 with groupID 0
debug 2022-02-28 10:58:30: No converter available for 'TS011F_plug_1' with cluster 'manuSpecificTuya_3' and type 'attributeReport' and data '{"53249":4}'
debug 2022-02-28 10:58:30: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsVoltage":0}' from endpoint 1 with groupID 0
info 2022-02-28 10:58:30: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0.36,"energy":2.51,"indicator_mode":null,"linkquality":69,"power":79,"power_outage_memory":"on","state":"OFF","update":{"state":null},"update_available":null,"voltage":0}'
debug 2022-02-28 10:58:30: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":0}' from endpoint 1 with groupID 0
debug 2022-02-28 10:58:30: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsCurrent":0}' from endpoint 1 with groupID 0
info 2022-02-28 10:58:30: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0.36,"energy":2.51,"indicator_mode":null,"linkquality":69,"power":0,"power_outage_memory":"on","state":"OFF","update":{"state":null},"update_available":null,"voltage":0}'
info 2022-02-28 10:58:30: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0,"energy":2.51,"indicator_mode":null,"linkquality":69,"power":0,"power_outage_memory":"on","state":"OFF","update":{"state":null},"update_available":null,"voltage":0}'
debug 2022-02-28 10:58:35: Received MQTT message on 'zigbee2mqtt/iMac/set' with data 'ON'
debug 2022-02-28 10:58:35: Publishing 'set' 'state' to 'iMac'
info 2022-02-28 10:58:35: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0,"energy":2.51,"indicator_mode":null,"linkquality":47,"power":0,"power_outage_memory":"on","state":"ON","update":{"state":null},"update_available":null,"voltage":0}'
debug 2022-02-28 10:58:35: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID 0
debug 2022-02-28 10:58:36: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'genOnOff', data '{"onOff":0}' from endpoint 1 with groupID 0
info 2022-02-28 10:58:36: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0,"energy":2.51,"indicator_mode":null,"linkquality":47,"power":0,"power_outage_memory":"on","state":"OFF","update":{"state":null},"update_available":null,"voltage":0}'
debug 2022-02-28 10:58:37: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'manuSpecificTuya_3', data '{"53249":0}' from endpoint 1 with groupID 0
debug 2022-02-28 10:58:37: No converter available for 'TS011F_plug_1' with cluster 'manuSpecificTuya_3' and type 'attributeReport' and data '{"53249":0}'
debug 2022-02-28 10:58:37: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsVoltage":241}' from endpoint 1 with groupID 0
info 2022-02-28 10:58:37: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0,"energy":2.51,"indicator_mode":null,"linkquality":47,"power":0,"power_outage_memory":"on","state":"OFF","update":{"state":null},"update_available":null,"voltage":241}'
debug 2022-02-28 10:58:41: Received MQTT message on 'zigbee2mqtt/iMac/set' with data 'ON'
debug 2022-02-28 10:58:41: Publishing 'set' 'state' to 'iMac'
info 2022-02-28 10:58:41: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0,"energy":2.51,"indicator_mode":null,"linkquality":47,"power":0,"power_outage_memory":"on","state":"ON","update":{"state":null},"update_available":null,"voltage":241}'
debug 2022-02-28 10:58:42: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'genOnOff', data '{"onOff":1}' from endpoint 1 with groupID 0
info 2022-02-28 10:58:42: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0,"energy":2.51,"indicator_mode":null,"linkquality":47,"power":0,"power_outage_memory":"on","state":"ON","update":{"state":null},"update_available":null,"voltage":241}'
debug 2022-02-28 10:58:56: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":39}' from endpoint 1 with groupID 0
info 2022-02-28 10:58:56: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0,"energy":2.51,"indicator_mode":null,"linkquality":51,"power":39,"power_outage_memory":"on","state":"ON","update":{"state":null},"update_available":null,"voltage":241}'
debug 2022-02-28 10:58:59: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsCurrent":171}' from endpoint 1 with groupID 0
info 2022-02-28 10:58:59: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0.17,"energy":2.51,"indicator_mode":null,"linkquality":47,"power":39,"power_outage_memory":"on","state":"ON","update":{"state":null},"update_available":null,"voltage":241}'
debug 2022-02-28 10:59:01: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":95}' from endpoint 1 with groupID 0
info 2022-02-28 10:59:01: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0.17,"energy":2.51,"indicator_mode":null,"linkquality":47,"power":95,"power_outage_memory":"on","state":"ON","update":{"state":null},"update_available":null,"voltage":241}'
debug 2022-02-28 10:59:03: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsCurrent":392}' from endpoint 1 with groupID 0
info 2022-02-28 10:59:03: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0.39,"energy":2.51,"indicator_mode":null,"linkquality":47,"power":95,"power_outage_memory":"on","state":"ON","update":{"state":null},"update_available":null,"voltage":241}'
debug 2022-02-28 10:59:10: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":107}' from endpoint 1 with groupID 0
info 2022-02-28 10:59:10: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0.39,"energy":2.51,"indicator_mode":null,"linkquality":47,"power":107,"power_outage_memory":"on","state":"ON","update":{"state":null},"update_available":null,"voltage":241}'
debug 2022-02-28 10:59:12: Received Zigbee message from 'iMac', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"rmsCurrent":458}' from endpoint 1 with groupID 0
info 2022-02-28 10:59:12: MQTT publish: topic 'zigbee2mqtt/iMac', payload '{"child_lock":null,"current":0.46,"energy":2.51,"indicator_mode":null,"linkquality":47,"power":107,"power_outage_memory":"on","state":"ON","update":{"state":null},"update_available":null,"voltage":241}'
