Zigbee problems since 100.3 upgrade
Since upgrading to 0.100.3 today, my zigbee performance has gone down the drain. I am using ZHA with a conbee 2 stick. It has been running fine previously. I have not made any changes to my zigbee network today. It will work for a bit after a restart, but then it stops working some time later.
Looking through the homeassistant log I have found these entries:
2019-10-23 17:51:16 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.write_parameter' command
2019-10-23 17:51:16 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.7/site-packages/zigpy_deconz/zigbee/application.py", line 35, in _reset_watchdog
    await self._api.write_parameter(NetworkParameter.watchdog_ttl, 3600)
  File "/usr/local/lib/python3.7/site-packages/zigpy_deconz/api.py", line 169, in _command
    return await asyncio.wait_for(fut, timeout=COMMAND_TIMEOUT)
  File "/usr/local/lib/python3.7/asyncio/tasks.py", line 449, in wait_for
    raise futures.TimeoutError()
concurrent.futures._base.TimeoutError
2019-10-23 17:51:17 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.aps_data_indication' command
But I have no idea where to go from here debugging this. Any help of suggestions would be appreciated.
Cheers.
Time to eat humble pie.
Turns out I had left zigbee2mqtt stopped, but with start on boot still enabled. So I think the process of updating hass triggered a reboot (as opposed to just a restart). And I’m guessing it was grabbing the conbee before ZHA could.
Disabling (and removing it this time) has fixed the problem.
