ZigBee relay no neutral dimmer
Hello, I have been trying to find a ZigBee relay to place behind the dumb switches with no neutral and dimming capabilities, but I haven’t found any. Do they even exist or should I use the Shelly ones with wifi instead?
A relay doesn’t ever have dimming capabilities.
What you want is a dimmer switch, but before we can give you advices we need to know what country you are in.
Hi, this one for example does, buy I can’t find a ZigBee equivalent.
I’m based in Spain, thanks!
Here is dimmers.
No neutral is harder to find. But there are some that work with a bypass you install at the light.
This one is the only no-neutral dimming device I could find in Z2M based on a quick search. There might be more, but it’s better than nothing.
Edit: didn’t load all results when I searched earlier. There’s 2 more devices listed:
Single gang
Double gang
There is also this version if you want to remove the switch.
O have this one or a similar, and it works with no neutral if you use a bypass
Thanks a lot! I will give them a try
