Hey all -
Up until recently, I’ve only been using Shelly devices in my home for home automation - smartening up garage door openers, freezers, space heaters and switches and outlets.
I just started using Zigbee out of necessity for a project we completed in our kitchen - under cabinet LED strip lighting. I couldn’t find a good Wi-Fi RGBCCT controller that worked with Home Assistant so I went with one of the Gledopto (Model GL-C-008) controllers along with some BTF Lighting RGBCCT LED Strips. They look great - very bright, beautiful colors and the quality of the warm white light is perfect.
I went with a Conbee II Zigbee USB stick and am using ZHA.
We were mostly going to use the lighting as background lighting controlled by Circadian lighting. The under cabinet lighting is bright enough - and the light is so pleasant - that the family is using the lights as the primary kitchen lights. So I’m looking for a remote, or a switch panel, or something… to mount in the kitchen for a controller. The kids don’t have phones and it sucks looking for a phone to just turn on some lights.
Looking at the Zigbee device database from Blackadder I’ve found several different remotes that are exactly what I have in mind - here’s an example - ROBB RGB+CCT Remote Control.
This particular remote is sold by a Dutch company and from the device database page it is only showing Zigbee2MQTT support.
Does anyone know of a remote similar to the one I linked to that works with ZHA and is available in the US? Alternatively…if there is one that is available to the US but only works with Zigbee2MQTT I’m not opposed to setting all that up if I have to. I have a couple of simpler 4 button scene remotes on the way to test out but I’d really like one that can do full color/warmth/brightness control like the one I linked.
Thanks all!
