I’, trying to use a Sylvania light switch with HA. The auto-discovery recognizes it as a CentralLite sensor and thinks it’s detecting temperature. I’ve tried to over ride this:
zha:
usb_path: /dev/ttyUSB1
database_path: /config/zha.db
First this way:
- platform: zigbee
type: analog
Then this way:
- platform: zigbee
entity: sensor.centralite_3130_00f8e58e_1
type: analog
And I keep getting this:
2018-01-20 23:17:48 ERROR (MainThread) [homeassistant.setup] Error during setup of component zigbee
File “/usr/lib/python3.6/site-packages/homeassistant/setup.py”, line 199, in _async_setup_component
component.setup, hass, processed_config)
File “/usr/lib/python3.6/asyncio/futures.py”, line 332, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.6/asyncio/tasks.py”, line 250, in _wakeup
future.result()
File “/usr/lib/python3.6/asyncio/futures.py”, line 245, in result
raise self._exception
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/zigbee.py”, line 90, in setup
usb_device = config[DOMAIN].get(CONF_DEVICE, DEFAULT_DEVICE)
I’ve tried editing the DB file. No luck. There has to be some way to make this work, no?
