Zigbee smart radiator (hama/tuya - TS0601) is read only
I am currently in the process of unifying my smart home because it was getting on my nerves that almost every device needed its own hub. So I bought a rasbee module for my raspi and installed hassio. After a few problems was then relatively easy to connect most (except phillips hue there I still have to find the remote for the reset) with hassio (and the zigbee addon, not deconz).
Now I have only one problem: I have three smart themostats which are all the same model. However, one of the two is about 2 months old and the other two already about 1 year. The connection works fine with all three but the newer one seems to be read only. So I can only read the data, like temperature or current heat setting but I can’t change it. When I do, the value just jumps back after a few seconds and never arrives at the thermostat.
I have already created two diagnostic data files:
The “original text” (on the left side) is the new one which is read only.
The “changed text” (on the right side) is the old one which works as expected.
My guess is you need to revise the quirk to use the newer one. I’ve had the same issue with TS011F smart plugs.
Googling the model (_TZE200_h4cgnbzg) took me to this thread which describes exactly your issue:
perhaps a solution is in there.
Oh thank you. I will then continue there ^^
