Zigbee smoke detectors go offline
Hello!
I am new to Home Assistant but I am having a lot of fun so far by connecting Zigbee devices to my network. All my devices seem to work fine except of my smoke detectors. I have 3 smoke detectors from the brand “KlikAanKlikUit” and they are placed on every floor of my house. The issue I am having is that they randomly going “Unknown”, “Unavailable” or “Offline” and online again in Home Assistant. It is never the case that all 3 of them are online there is always 1 or 2 that are “Unknown”. Is there something wrong with my Zigbee network? I already added a Zigbee extender which did not make any difference. Or is there another reason why devices can have this behavior?
I added an image of my Zigbee network.
Thanks in advance.
My history tab for the logs over the weekend:
Hi David, welcome to the forum!
So you also have other zigbee devices then these smoke detectors and only the smoke detectors go offline?
What integration are you using and which coordinator/extender are you using and do you use extension cables for you coordinator, which is in a USB2.0 port?
Which smoke detectors do you use?
Hey Nick, thank you!
Yes I have 7 other Zigbee devices running without any issues. I am using the “Zigbee Home Automation” integration on a mini pc server which runs Home Assistant in docker. To the server I attached the “Sonoff Zigbee 3.0 USB Dongle Plus” usb dongle into a USB3.0 port. I don’t use any other extension cables. I do have a “TRÅDFRI” signal booster from Ikea, but I don’t notice any difference with or without the booster. The smoke detectors have the same issues and the rest of my devices are still running correctly. The smoke detectors I use are from the brand “KlikAanKlikUit”.
Do they (kaku) only have 1 type of smoke detector?
USB 3.0 is a nogo and using an extension cable is advised for zigbee.
Yes they only have 1 type of smoke detector. I did not know inserting the Zigbee dongle in a 3.0 port was a bad thing. With an extension cable you mean an extension cable inserted into a USB2.0 port attached with the “Sonoff Zigbee 3.0 USB Dongle Plus”? Can you explain a bit why this is better?
USB2.0 & extension cable are two of the most shouted things when having zigbee issues.
Some stuff to read:
Thanks I will read into it!
Just wanted to say that switching to an usb 2.0 extension cable fixed my issue, thank you!
Good you got it solved that way and thanks for letting me know!
Have fun on your automation path.
I have the exact same issue, but with 3 from my 10 Klikaanklikuit smoke detectors. All my other sensors and end devices stay online. My Sonoff zigbee stick is 2 meters away from my Raspberry Pi with an usb extension cable plugged into usb2.0.
This thread is two years old (and marked “solved”). You might get better results by starting a new one.
It would be helpful if you could give more details about your network (number of routers/end devices, location problem devices, etc.).
Thanks! Made a new one.
