my Zigbee Mesh used to work fine (39 devices, 24 of them Routers).
About two weeks ago it began to more an more run into problems.
All Zigbee devices go offline at exactly the same time and come up again at exactly the time but there state is seen as chagend what causes tons of automations to start.
Offline time slightly varies.
I also observed that there is a value without a proper name ar the zigbee. coordinator that increases linear and than drops.
Maybe someone has a hint what it is.
The Basics have all been checked long time ago:
- Coordinator connted on USB 2 Port with a ling USB 2 cable
- Coordinator placed away from other devices
Infos:
- Core2024.8.1
- Supervisor2024.08.0
- Operating System13.1
- Frontend20240809.0
Hardware:
RaspberryPi 4B 8GB
Sonoff CC2652 / ZBDongle-P (Firmware: Z-Stack 20210708)
No Docker HA as Raspi Image/OS
Configuration:
Netzwerkeinstellungen
9B0D
PAN ID
f7:a9:ba:14:c9:04:cc:a7
Extended PAN ID
20
Channel
00:12:4b:00:24:c2:9b:8c
Coordinator IEEE
znp
Radio type
/dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
Serial port
115200
Baudrate
7200
DropTime netpowered
99000
DropTime battery powered
DebugLog:
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2024.8.1",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.12.4",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Berlin",
"os_name": "Linux",
"os_version": "6.6.31-haos-raspi",
"supervisor": "2024.08.0",
"host_os": "Home Assistant OS 13.1",
"docker_version": "26.1.4",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"feedparser": {
"documentation": "https://github.com/custom-components/feedparser/blob/2be3736892328476d4728f02083e4a161e9c0d15/README.md",
"version": "0.1.11",
"requirements": [
"feedparser==6.0.10"
"hacs": {
"documentation": "https://hacs.xyz/docs/configuration/start",
"version": "1.34.0",
"requirements": [
"aiogithubapi>=22.10.1"
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"after_dependencies": [
"onboarding",
"usb"
"codeowners": [
"dmulcahey",
"adminiuga",
"puddly",
"TheJulianJES"
"config_flow": true,
"dependencies": [
"file_upload"
"documentation": "https://www.home-assistant.io/integrations/zha",
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp",
"zha",
"universal_silabs_flasher"
"requirements": [
"universal-silabs-flasher==0.0.22",
"zha==0.0.30"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "10C4",
"pid": "EA60",
"description": "*slzb-07*",
"known_devices": [
"smlight slzb-07"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "0403",
"pid": "6015",
"known_devices": [
"Conbee III"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"type": "_uzg-01._tcp.local.",
"name": "uzg-01*"
"type": "_slzb-06._tcp.local.",
"name": "slzb-06*"
"type": "_xzg._tcp.local.",
"name": "xzg*"
"type": "_czc._tcp.local.",
"name": "czc*"
"is_built_in": true
"setup_times": {
"null": {
"setup": 0.0001354260602965951
"60e85933565ca0b5cbe7211d6ea39d36": {
"wait_import_platforms": -0.06409579701721668,
"wait_base_component": -0.0024364260025322437,
"config_entry_setup": 41.72465967503376
"data": {
"config": {},
"config_entry": {
"created_at": "1970-01-01T00:00:00+00:00",
"data": {
"device": {
"path": "/dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0",
"flow_control": null,
"baudrate": 115200
"radio_type": "znp"
"disabled_by": null,
"domain": "zha",
"entry_id": "60e85933565ca0b5cbe7211d6ea39d36",
"minor_version": 1,
"modified_at": "2024-09-06T17:30:20.271083+00:00",
"options": {
"custom_configuration": {
"zha_options": {
"enhanced_light_transition": true,
"consider_unavailable_battery": 99000,
"default_light_transition": 0,
"light_transitioning_flag": true,
"always_prefer_xy_color_mode": true,
"group_members_assume_state": true,
"enable_identify_on_join": true,
"consider_unavailable_mains": 7200
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "usb",
"title": "Sonoff Zigbee 3.0 USB Dongle Plus - Sonoff Zigbee 3.0 USB Dongle Plus",
"unique_id": "**REDACTED**",
"version": 4
"application_state": {
"node_info": {
"nwk": 0,
"ieee": "**REDACTED**",
"logical_type": 0,
"model": "CC2652",
"manufacturer": "Texas Instruments",
"version": "Z-Stack 20210708"
"network_info": {
"extended_pan_id": "**REDACTED**",
"pan_id": 39693,
"nwk_update_id": 1,
"nwk_manager_id": 0,
"channel": 20,
"channel_mask": 2048,
"security_level": 5,
"network_key": "**REDACTED**",
"tc_link_key": {
"key": [
90,
105,
103,
66,
101,
101,
65,
108,
108,
105,
97,
110,
99,
101,
48,
57
"tx_counter": 0,
"rx_counter": 0,
"seq": 0,
"partner_ieee": "**REDACTED**"
"key_table": [],
"children": [],
"nwk_addresses": {},
"stack_specific": {
"zstack": {
"tclk_seed": "aff216ba60616ae96faface13d4e7f55"
"metadata": {
"zstack": {
"TransportRev": 2,
"ProductId": 1,
"MajorRel": 2,
"MinorRel": 7,
"MaintRel": 1,
"CodeRevision": 20210708,
"BootloaderBuildType": 0,
"BootloaderRevision": null
"source": "[email protected]"
"counters": {
"Retry_NONE": {
"0": {
"__type": "<class 'zigpy.state.Counter'>",
"repr": "Counter(name=0, _raw_value=2000, reset_count=0, _last_reset_value=0)"
"1": {
"repr": "Counter(name=1, _raw_value=1, reset_count=0, _last_reset_value=0)"
"broadcast_counters": {},
"device_counters": {},
"group_counters": {}
"energy_scan": {
"11": 32.94117647058823,
"12": 57.64705882352941,
"13": 54.11764705882353,
"14": 43.529411764705884,
"15": 45.88235294117647,
"16": 57.64705882352941,
"17": 62.35294117647059,
"18": 63.529411764705884,
"19": 58.8235294117647,
"20": 41.1764705882353,
"21": 29.41176470588235,
"22": 22.352941176470587,
"23": 22.352941176470587,
"24": 10.588235294117647,
"25": 45.88235294117647,
"26": 45.88235294117647
"versions": {
"bellows": "0.40.3",
"zigpy": "0.65.3",
"zigpy_deconz": "0.23.3",
"zigpy_xbee": "0.20.2",
"zigpy_znp": "0.12.4",
"zigpy_zigate": "0.13.1",
"zhaquirks": "0.0.118",
"zha": "0.0.30"
"devices": [
"model": "CC2652",
"logical_type": "Coordinator"
"manufacturer": "eWeLink",
"model": "DS01",
"logical_type": "EndDevice"
"model": "DS01",
"manufacturer": "_TZ3000_2putqrmw",
"model": "TS011F",
"logical_type": "Router"
"model": "DS01",
"model": "DS01",
"model": "DS01",
"model": "DS01",
"model": "DS01",
"model": "TS011F",
"model": "TS011F",
"model": "TS011F",
"model": "TS011F",
"model": "TS011F",
"model": "TS011F",
"manufacturer": "LUMI",
"model": "lumi.switch.l2aeu1",
"model": "TS011F",
"model": "TS011F",
"model": "TS011F",
"model": "TS011F",
"model": "TS011F",
"model": "TS011F",
"model": "DS01",
"model": "DS01",
"model": "DS01",
"model": "TS011F",
"manufacturer": "innr",
"model": "RB 245",
"model": "RB 245",
"model": "RB 245",
"model": "TS011F",
"model": "TS011F",
"model": "TS011F",
"model": "DS01",
"manufacturer": "Signify Netherlands B.V.",
"model": "LWA017",
"manufacturer": "IKEA of Sweden",
"model": "Remote Control N2",
"model": "TS011F",
"model": "TS011F",
"model": "TS011F",
