i’m running Homeassistant under Proxmox for several month without problems so far. But now… ;-):
Suddenly the Sonoff Zigbee USB Stick could not be found by the system. The configuration is set like this as before:
port: >- /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
But the protocoll looks like this:
[09:38:04] INFO: Preparing to start... [09:38:04] INFO: Socat not enabled [09:38:05] INFO: Starting Zigbee2MQTT... Zigbee2MQTT:info 2023-10-08 09:38:07: Logging to console and directory: '/config/zigbee2mqtt/log/2023-10-08.09-38-07' filename: log.txt Zigbee2MQTT:info 2023-10-08 09:38:07: Starting Zigbee2MQTT version 1.33.1 (commit #unknown) Zigbee2MQTT:info 2023-10-08 09:38:07: Starting zigbee-herdsman (0.19.0) Zigbee2MQTT:error 2023-10-08 09:38:27: Error while starting zigbee-herdsman Zigbee2MQTT:error 2023-10-08 09:38:27: Failed to start zigbee Zigbee2MQTT:error 2023-10-08 09:38:27: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions Zigbee2MQTT:error 2023-10-08 09:38:27: Exiting... Zigbee2MQTT:error 2023-10-08 09:38:27: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) at ZStackAdapter.start (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:103:27) at Controller.start (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:132:29) at Zigbee.start (/app/lib/zigbee.ts:60:27) at Controller.start (/app/lib/controller.ts:101:27) at start (/app/index.js:107:5)
Restarts, reboots and so on didn’t solve the problem, has anyone here more ideas to fix it?
Thanks a lot in advance of any solution!
Norbert
