I am interested because I prefer to change the Hue Hub. The most annoying fact is that after a power cut it turns ON all the lights … incredibly dumb thing to do.
I wish that with a zigbee stick, hass, I can retain the value (pi3 with hass is under UPS) of the lights and when the power is back on, all lights come back at their previous state
What do you mean, “Zigbee stick for Europe”, or are you talking about availability in Europe? The GoControl QuickStick Combo HUSBZB-1 can be ordered, as far as I see, from discounthomeautomation.com ($ 36), and they seem to ship to Europe. That is the device that Russell Cloran tested in his all new native ZigBee Integration.
By the way, four days ago I asked Nortek, who’s subsidiary GoControl obviously is, whether they planned to upgrade the QuickStick to Zigbee 3.0, and when that could happen. No reply so far…
@anon35356645 (and @SebasT): discounthomeautomation.com cites the tech specs of the QuickStick Combo with i.a. “ZigBee Operating Frequency: 2.4 GHz”, and that is because to my best knowledge ZigBee does not have different frequencies in different countries the world over. Z-Wave, on the other Hand, has an operating frequency of 908.42 MHz in the U.S., but Europe uses 868 MHz. The Z-Wave part of the QuickStick Combo would certainly be waisted in Europe, but the ZigBee part should work just fine!
Peter
The Nortek stick is dual zigbee and zwave.
Its zwave that is regional.
Zigbee is 2.4ghz world wide, and hence Philips hue bulbs will work anywhere (assuming voltage requirements are met)
Unless it uses EmberZNet stack via ezsp protocol it’s not compatible.
If you view the comments against the PR if GitHub for zigbee update it mentions that the Dresden units are not compatible.
Really seems to be limited to silicon labs devices.
Just wish we could get a full list.
At de.farnell.com the long range version ETRX357USB-LRS+8M costs 43,37 € plus about 6 € shipping (Germany). Depending on the report you are going to give us, divdav, this is probably what I’m going to try.
I bought one to test with and it turns out it cannot be used.
EZSP functionality requires having access to the full EmberZNet wireless mesh stack to be able to update the firmware on the dongle. Access to the wireless mesh stacks requires the purchase of one of the full Mesh Networking development kits from Silicon Labs
What other options do we have? As soon as I find a working stick I will post it here.
