Zigbee Stuck on uploading file
By the way, the Z-Wave radio chip inside that adapter is also a few generations old, however not as old as the Zigbee radio chip in it. Not sure why why some people still recommend that old combo adapter when it is clearly better and easier in every way to have dedicated adapter for each IoT radio protocol. For Z-Wave I suggest you consider buying Zooz 800 Series Z-Wave USB Stick based on ZST39 (which is available preflashed with different firmware for various world RF regions however the hardware is the same for all).
Regardless of Zigbee Coordinator adapter, be sure to also read and follow this → https://community.home-assistant.io/t/zigbee-networks-how-to-guide-for-avoiding-interference-and-optimize-for-getting-better-range-coverage/515752 (Z-Wave range is better and is way less sensitive to interference if compare to Zigbee).
