New add-on for running zigpy-cli commands (Like Energy Scans)
I’ve created a new addon - TubesZB Zigpy-CLI Tools to run some of the zigpy-cli commands for anyone not comfortable with the command line and python. Or anyone just lazy :wink:
You’ll need to stop Zigbee2MQTT or ZHA before running the addon as only one thing can talk to the radio at a time.
It supports usb and network coordinators
Currently the addon supports the following commands from zigpy-cli
  • info - Reads the current network informationf from the radio
  • energy-scan - Runs an environmental RF Energy Scan to assist with identifying the best channel
  • form - create a network on a new coordinator
  • reset - Reset a coordinator - removing it’s network configuration
Happy to take feed back or the docs/experience with this.
Thanks!
Awesome!
For reference, if comfortable with using the command line then also check out zha-toolkit by @le_top
FYI, a benefit with mdeweerd’s “ZHA Toolkit” is that you do not need to stop the ZHA integration to use it, (and advanced users can optionally also build reusable automation blueprints that others to also reuse).
Thanks @Hedda The ZHA Tool Kit is good for advanced ZHA users. this addon is intended more for troubleshooting, and assisting users not comfortable with the command line.
version 0.2.2 adds backup and restore functions too.
Wow thanks @tube0013 !
Is it also possible to reset a SONOFF Zigbee Dongle Plus (P-Model) using the Router Firmware?
I am searching for a solution described in the following thread but I don’t know how…
Thanks a lot in advance!
Best,
Dominik
Note that resetting a Zigbee Coordinator does not change its unique IEEE address, and to need to write a new unique IEEE address with a flasher tool if re-purposing a previously used Zigbee Coordinator as a Zigbee Router so do not get two devices on the Zigbee network with same IEEE address. All devices on the same Zigbee network need to have unique IEEE addresses, see my reply in your other thread:
Hello!!!
I download it and try but have some problems.
Conbee2 as adapter
I config the conbee adapter, the radio type as deconz, and the backup file name. But when i push save i got this error:
No se pudo guardar la configuración del complemento, Missing required option 'network_device' in TubesZB Zigpy-CLI Tools (d0f5a498_tzb-zigpy-cli-tools). Got {'network_device': None, 'device': '/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2463707-if00', 'device_type': False, 'action': None, 'radio_type': 'deconz', 'baudrate': '115200', 'backup_filename': 'backup_zigbee.js'}
zigbee2mqtt is stoped, and works as addon of haos
Make sure the “use network device” toggle is turned off, but still enter something in the “Network Device” field.
I just entered a “0”.
thanks!!!
exact this was the error, I put “0” in network device and runs.
either the “use network device” is turned off.
i receive a warning in the logs but aparently works fine
I am struggling to follow the instructions and I do not know where my mistake is.
  1. I quit z2mqtt.
  2. I open the TubesZB Zigpy-CLI Tools config
  3. I choose my conbee2 from the list
  4. I enter my HomeAssistantIP to fill the blank
  5. I chose deconz as radio type.
  6. I left the baudrate at 115200
  7. I chose “backup”
  8. I entered the file name “conbee_II”
  9. I unplugged the conbee2 and plugged in the conbee3
  10. I rebootet my mini computer running HA
  11. I ran the TubesZB Zigpy-CLI Tools restore option on my conbee 3 (new file path).
  12. I quit the add on.
  13. I start z2mqtt with the new device path, specific to the conbee 3
  14. z2mqtt is stuck in a loop where all it shows in the logs is 3 lines, each with “starting…” in green writing.
I am assuming it cannot recognize the conbee3 but I do not know what else to do. Can anyone help me out here?
Thanks!
I thought I read somewhere the conbee3 is based on an efr32 chip, does ezsp work with it?
Unfortunately I get an error in the following scenario:
  • I backup my conbee 2 choosing deconz as radio type.
  • I insert my conbee 3 and reboot the computer.
  • I choose restore with “ezsp” from the save file
I appreciate the help!
Does anyone else have any idea?
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service banner: starting
 Add-on: TubesZB Zigpy-CLI Tools
 TubesZB Zigpy-CLI Toolsadd-on
 Add-on version: 0.2.2
 You are running the latest version of this add-on.
 System: Home Assistant OS 11.5  (amd64 / generic-x86-64)
 Home Assistant Core: 2024.2.1
 Home Assistant Supervisor: 2024.01.1
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service zigpy-cli: starting
[17:42:00] INFO: Directoty Exists
[17:42:01] INFO: Running zigpy - restore on /dev/ttyUSB0 to /config/tzb-zigpy-cli-tools/conbee_II
  File "/usr/local/lib/python3.11/site-packages/bellows/uart.py", line 262, in reset
    return await self._reset_future
asyncio.exceptions.CancelledError
  File "/usr/local/bin/zigpy", line 8, in <module>
    sys.exit(cli())
  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 1157, in __call__
    return self.main(*args, **kwargs)
  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 1078, in main
    rv = self.invoke(ctx)
  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 1688, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 1434, in invoke
    return ctx.invoke(self.callback, **ctx.params)
  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 783, in invoke
    return __callback(*args, **kwargs)
  File "/usr/local/lib/python3.11/site-packages/click/decorators.py", line 45, in new_func
    return f(get_current_context().obj, *args, **kwargs)
  File "/usr/local/lib/python3.11/site-packages/zigpy_cli/cli.py", line 20, in inner
    return loop.run_until_complete(cmd(*args, **kwargs))
  File "/usr/local/lib/python3.11/asyncio/base_events.py", line 653, in run_until_complete
    return future.result()
  File "/usr/local/lib/python3.11/site-packages/zigpy_cli/radio.py", line 143, in restore
    await app.connect()
  File "/usr/local/lib/python3.11/site-packages/bellows/zigbee/application.py", line 148, in connect
    await ezsp.startup_reset()
  File "/usr/local/lib/python3.11/site-packages/bellows/ezsp/__init__.py", line 125, in startup_reset
    await self.reset()
  File "/usr/local/lib/python3.11/site-packages/bellows/ezsp/__init__.py", line 151, in reset
    await self._gw.reset()
  File "/usr/local/lib/python3.11/site-packages/bellows/uart.py", line 261, in reset
    async with asyncio_timeout(RESET_TIMEOUT):
  File "/usr/local/lib/python3.11/asyncio/timeouts.py", line 111, in __aexit__
    raise TimeoutError from exc_val
TimeoutError
[17:42:07] INFO: zigpy-cli-up script exited with code 1
s6-rc: warning: unable to start service zigpy-cli: command exited 1
s6-rc: info: service banner: stopping
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
This is the message I get when using “deconz” as radio type. It also seems to not work properly:
[17:45:41] INFO: Directoty Exists
[17:45:41] INFO: Running zigpy - restore on /dev/ttyUSB0 to /config/tzb-zigpy-cli-tools/conbee_II
2024-02-12 17:45:42.650 d0f5a498-tzb-zigpy-cli-tools zigpy.application WARNING Unknown device AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0xD905)
2024-02-12 17:45:42.681 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 22, Status: TXStatus.SUCCESS
2024-02-12 17:45:42.745 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 23, Status: TXStatus.SUCCESS
2024-02-12 17:45:42.809 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 24, Status: TXStatus.SUCCESS
2024-02-12 17:45:42.873 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 25, Status: TXStatus.SUCCESS
2024-02-12 17:45:42.937 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 26, Status: TXStatus.SUCCESS
2024-02-12 17:45:43.001 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 28, Status: TXStatus.SUCCESS
2024-02-12 17:45:43.065 d0f5a498-tzb-zigpy-cli-tools asyncio ERROR Task exception was never retrieved
future: <Task finished name='discover_unknown_device_from_packet-nwk=0xD905' coro=<ControllerApplication._discover_unknown_device() done, defined at /usr/local/lib/python3.11/site-packages/zigpy/application.py:942> exception=DeliveryError("Failed to enqueue packet: CommandError('<CommandId.aps_data_request: 18>, status: <Status.NO_NETWORK: 6>')")>
  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/zigbee/application.py", line 508, in send_packet
    await self._api.aps_data_request(
  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 871, in aps_data_request
    rsp = await self.send_command(
  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 508, in send_command
    return await self._command(cmd, **kwargs)
  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 586, in _command
    return await fut
zigpy_deconz.exception.CommandError: <CommandId.aps_data_request: 18>, status: <Status.NO_NETWORK: 6>
  File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 945, in _discover_unknown_device
    return await zigpy.zdo.broadcast(
  File "/usr/local/lib/python3.11/site-packages/zigpy/device.py", line 623, in broadcast
    return await app.broadcast(
  File "/usr/local/lib/python3.11/site-packages/zigpy/application.py", line 921, in broadcast
    await self.send_packet(
  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/zigbee/application.py", line 522, in send_packet
    raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to enqueue packet: CommandError('<CommandId.aps_data_request: 18>, status: <Status.NO_NETWORK: 6>')
2024-02-12 17:45:46.168 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.zigbee.application WARNING Unexpected transmit confirm for request id 30, Status: TXStatus.SUCCESS
[17:45:46] INFO: Action Complete
[17:45:46] INFO: zigpy-cli-up script exited with code 0
s6-rc: info: service zigpy-cli successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service zigpy-cli: stopping
s6-rc: info: service zigpy-cli successfully stopped
No they are using a custom firmware with their own proprietary deconz serial protocol interface, same as ConBee II and Raspbee II, see:
zigpy-cli should bowever have the same compatible with ConBee III as with ConBee II via the zigpy-deconz radio library.
Must be missing something. Installed zigpy-cli some time ago … not even sure how long ago. Used it back then to check channel traffic/clutter.
Was recently informed (by HA) of an upgrade. Upgraded, now at 0.3.0.0.
Decided I needed to use it again. SSH in to the HA server. Type zigpy. Get
-bash: zigpy: command not found
Huh? What am I not doing now that I did do back then?
Thanks for any thoughts.
@tube0013 FYI, puddly who is one of the lead developers of zha and zigpy is working in adding a new “Advanced energy scan” feature/function to zigpy-cli (command line interface for zigpy radios used by zha) as well as “implement a standard interface for network scanning” for zigpy. Maybe you could look into creating frontend interface for that to make it more accessible to all users? See:
and
Also see related development discussion here:
As well as these for Silicon Labs EmberZNet EZSP and Texas Instruments Z-Stack ZNP zigpy radios respectively:
I’m aware no need to post here, it will be ready when it is ready. I watch the zigpy repositories closely and am in contact with puddly and dmulcahey.
Hi!
Sorry if that is a “dumb” question, but I just found this post and wondered if it’s possible to migrate my zigbee2mqtt devices from Conbee 2 to Sonoff ZBDongle-E using zigpy-cli or do I have to re-pair all devices step by step?
Thanks for the help.
Give it a shot, backup the conbee and restore the -e and update the z2m config to use ember… just make sure you update the sonoff -e to a 7.4.x firmware build.
Last weekend I’ve sucessfully migrated my raspberry PI hosted Home Assistant environment (HAOS with Zigbee2MQTT) from Conbee II stick to a HP T630 hosted environment using a new Sonoff ZBDongle-E (updated firmware - ember)
Phase 1
  1. Took full Homeassistant backup from Raspberry PI and powered off the Raspberry PI
  2. Restored the full Homeassistant backup to the HP T630 with the Conbee II connected to this device
Result Phase 1: Home Assistant worked without any issues and also Zigbee2MQTT (Z2M) was able to connect to all of my 30+ devices without issue or repairing
Phase 2
  1. Installed TubesZB Zigpy-CLI Tools Add-On
  2. Stopped Z2M
  3. Made a backup of my Zigbee Conbee II with the TubesZB Zigpy-CLI Tools Add-On (Device: Conbee II; Network Device: could be left blank so I put in the local IP address of my HP T630, Radio Type: Deconz, Baudrate: 115200, Enable Verbose Logging: True)
  4. Removed the Conbee II from device
  5. Inserted the Sonoff ZBDongle-E (which I previously updated the firmware for to ncp-uart-hw-v7.4.4.0-zbdonglee-115200.gbl)
  6. Restored from the backup file using Device: Sonoff ZBDongle-E; Network Device: could be left blank so I put in the local IP address of my HP T630, Radio Type: ember; Baudrate: 115200; Enable Verbose Logging: True
  7. Stopped the TubesZB Zigpy-CLI Tools Add-On
  8. Updated Z2M configration to “port: Sonoff ZBDongle-E; adapter: ember”
  9. Started Z2M
  10. Rebooted HP T630 device (reboot system)
Result Phase 2: Home Assistant worked without any issues and also Zigbee2MQTT (Z2M) was able to connect to most of my 30+ devices, some battery powered devices needed a little nudge (switch on/off) and then came back to connected state
All in all a very surprising sucessfull migration for which I reserved a whole sunday (wife was out) as I feared I would have to repair each and every zigbee device across the house. I think the whole process took me 2-3 hours.
As I had time to spare before F1 Abu Dhabi started, I also installed the “Home-Assistant-Matter-Hub” add-on via which I was able to expose all my zigbee devices to Google Home without any effort or paid subscription.
Happy Days !!!
Hi
I upgraded my Conbee 2 to an SMLight SLZB-06M, so from Deconz to Ember, following this guide and the add-on TubesZB Zigpy-CLI Tools.
I didn’t have to re-pair anything, and my 45 devices work, thank you for job.
Hi there, I’m trying to work with my RaspBeeII running on my Pi4, but it seems that the add-on can’t connect to it.
  • I have stopped Z2M
  • I have configured the Add-On using the same parameters:
    • Device: /dev/ttyAMA0
    • Radio Type: deconz
    • Baudrate: 115200 (haven’t changed it)
    • Zigpy-CLI Command: info
Below you can find the the error stack that I receive. It seems a very generic error and doesn’t provide much.
EDIT: Resolved. It needs a different baudrate (38400). I will open a PR to your Github Repo.
Can you help?
<s>s6-rc: info: service zigpy-cli: starting</s>
<s>[09:15:26] INFO: e[32me[0m</s>
<s>[09:15:26] INFO: e[32mDirectoty Existse[0m</s>
<s>[09:15:26] INFO: e[32mRunning zigpy - info on /dev/ttyAMA0e[0m</s>
<s>2025-05-27 09:15:31.656 d0f5a498-tzb-zigpy-cli-tools asyncio DEBUG Using selector: EpollSelector</s>
<s>2025-05-27 09:15:31.695 d0f5a498-tzb-zigpy-cli-tools zigpy.ota DEBUG Registering new OTA provider: Ledvance(url='https://api.update.ledvance.com/v1/zigbee/firmwares', manufacturer_ids=(4489, 4364))</s>
<s>2025-05-27 09:15:31.695 d0f5a498-tzb-zigpy-cli-tools zigpy.ota DEBUG Registering new OTA provider: Sonoff(url=None, manufacturer_ids=(4742,))</s>
<s>2025-05-27 09:15:31.696 d0f5a498-tzb-zigpy-cli-tools zigpy.ota DEBUG Registering new OTA provider: Inovelli(url=None, manufacturer_ids=(4655,))</s>
<s>2025-05-27 09:15:31.696 d0f5a498-tzb-zigpy-cli-tools zigpy.ota DEBUG Registering new OTA provider: ThirdReality(url=None, manufacturer_ids=(4659, 4877, 5127))</s>
<s>2025-05-27 09:15:31.699 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.uart DEBUG Connecting to /dev/ttyAMA0</s>
<s>2025-05-27 09:15:31.699 d0f5a498-tzb-zigpy-cli-tools zigpy.serial DEBUG Opening a serial connection to '/dev/ttyAMA0' (baudrate=115200, xonxoff=False, rtscts=False)</s>
<s>2025-05-27 09:15:31.700 d0f5a498-tzb-zigpy-cli-tools zigpy.serial DEBUG Connection made: SerialTransport(<_UnixSelectorEventLoop running=True closed=False debug=False>, <zigpy_deconz.uart.Gateway object at 0x7f97d9a2d0>, Serial<id=0x7f97d4dab0, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False))</s>
<s>2025-05-27 09:15:31.702 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.api DEBUG Sending CommandId.read_parameter{'parameter_id': <NetworkParameter.protocol_version: 34>, 'parameter': b''} (seq=1)</s>
<s>2025-05-27 09:15:33.505 d0f5a498-tzb-zigpy-cli-tools zigpy_deconz.api DEBUG No response to 'CommandId.read_parameter' command with seq 1</s>
<s>2025-05-27 09:15:33.506 d0f5a498-tzb-zigpy-cli-tools zigpy.serial DEBUG Waiting for serial port to close</s>
<s>2025-05-27 09:15:33.507 d0f5a498-tzb-zigpy-cli-tools zigpy.serial DEBUG Connection lost: None</s>
<s>Traceback (most recent call last):</s>
<s>  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 588, in _command</s>
<s>    return await fut</s>
<s>           ^^^^^^^^^</s>
<s>asyncio.exceptions.CancelledError</s>
<s>The above exception was the direct cause of the following exception:</s>
<s>  File "/usr/local/bin/zigpy", line 8, in <module></s>
<s>    sys.exit(cli())</s>
<s>             ^^^^^</s>
<s>  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 1161, in __call__</s>
<s>    return self.main(*args, **kwargs)</s>
<s>           ^^^^^^^^^^^^^^^^^^^^^^^^^^</s>
<s>  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 1082, in main</s>
<s>    rv = self.invoke(ctx)</s>
<s>         ^^^^^^^^^^^^^^^^</s>
<s>  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 1697, in invoke</s>
<s>    return _process_result(sub_ctx.command.invoke(sub_ctx))</s>
<s>                           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^</s>
<s>  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 1443, in invoke</s>
<s>    return ctx.invoke(self.callback, **ctx.params)</s>
<s>           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^</s>
<s>  File "/usr/local/lib/python3.11/site-packages/click/core.py", line 788, in invoke</s>
<s>    return __callback(*args, **kwargs)</s>
<s>           ^^^^^^^^^^^^^^^^^^^^^^^^^^^</s>
<s>  File "/usr/local/lib/python3.11/site-packages/click/decorators.py", line 45, in new_func</s>
<s>    return f(get_current_context().obj, *args, **kwargs)</s>
<s>           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^</s>
<s>  File "/usr/local/lib/python3.11/site-packages/zigpy_cli/cli.py", line 20, in inner</s>
<s>    return loop.run_until_complete(cmd(*args, **kwargs))</s>
<s>  File "/usr/local/lib/python3.11/asyncio/base_events.py", line 654, in run_until_complete</s>
<s>    return future.result()</s>
<s>           ^^^^^^^^^^^^^^^</s>
<s>  File "/usr/local/lib/python3.11/site-packages/zigpy_cli/radio.py", line 87, in info</s>
<s>    await app.connect()</s>
<s>  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/zigbee/application.py", line 98, in connect</s>
<s>    await api.connect()</s>
<s>  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 467, in connect</s>
<s>    await self.version()</s>
<s>  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 812, in version</s>
<s>    self._protocol_version = await self.read_parameter(</s>
<s>  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 831, in read_parameter</s>
<s>    rsp = await self.send_command(</s>
<s>          ^^^^^^^^^^^^^^^^^^^^^^^^</s>
<s>  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 507, in send_command</s>
<s>    return await self._command(cmd, **kwargs)</s>
<s>           ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^</s>
<s>  File "/usr/local/lib/python3.11/site-packages/zigpy_deconz/api.py", line 587, in _command</s>
<s>    async with asyncio_timeout(COMMAND_TIMEOUT):</s>
<s>  File "/usr/local/lib/python3.11/asyncio/timeouts.py", line 115, in __aexit__</s>
<s>    raise TimeoutError from exc_val</s>
<s>TimeoutError</s>
<s>[09:15:33] INFO: e[32mzigpy-cli-up script exited with code 1e[0m</s>
<s>s6-rc: warning: unable to start service zigpy-cli: command exited 1</s>
<s>s6-rc: info: service banner: stopping</s>
<s>```
