Running 24.4.4 on Ubuntu (as a snap).
Everything has been working for several months. Suddenly, and without any manual update or configuration change, HA is not connecting to the Sonoff zigbee dongle.
The dongle is connected and visible with lsusb:
Bus 003 Device 008: ID 1a86:55d4 QinHeng Electronics SONOFF Zigbee 3.0 USB Dongle Plus V2
I’ve done the usual reset/restart, rebooted the Ubuntu PC, checked the connections etc.
The mouse-over error was initially saying something about the Sonoff device but there was no way to copy that message and I couldn’t see it in the log. It now just says ‘Failed setup. Will retry.’
Log entry:
> Logger: homeassistant
> Source: /snap/home-assistant-snap/600/lib/python3.12/site-packages/homeassistant/runner.py:146
> First occurred: 11:29:20 (105 occurrences)
> Last logged: 12:53:30
> Error doing job: Exception in callback SerialTransport._read_ready()
> ValueError: (11, None) is not a valid NcpResetCode
> During handling of the above exception, another exception occurred:
> Traceback (most recent call last):
> File "/usr/lib/python3.12/asyncio/events.py", line 88, in _run
> self._context.run(self._callback, *self._args)
> File "/snap/home-assistant-snap/600/lib/python3.12/site-packages/serial_asyncio_fast/__init__.py", line 137, in _read_ready
> self._protocol.data_received(data)
> File "/snap/home-assistant-snap/600/lib/python3.12/site-packages/bellows/uart.py", line 84, in data_received
> self.frame_received(frame)
> File "/snap/home-assistant-snap/600/lib/python3.12/site-packages/bellows/uart.py", line 119, in frame_received
> self.rstack_frame_received(data)
> File "/snap/home-assistant-snap/600/lib/python3.12/site-packages/bellows/uart.py", line 160, in rstack_frame_received
> code, version = self._get_error_code(data)
> File "/snap/home-assistant-snap/600/lib/python3.12/site-packages/bellows/uart.py", line 193, in _get_error_code
> return t.NcpResetCode(data[2]), data[1]
> File "/snap/home-assistant-snap/600/lib/python3.12/site-packages/bellows/types/basic.py", line 216, in __call__
> return super().__call__(value, names, *args, **kwargs)
> File "/usr/lib/python3.12/enum.py", line 757, in __call__
> return cls.__new__(cls, value)
> File "/usr/lib/python3.12/enum.py", line 1179, in __new__
> raise exc
> File "/usr/lib/python3.12/enum.py", line 1156, in __new__
> result = cls._missing_(value)
> File "/snap/home-assistant-snap/600/lib/python3.12/site-packages/bellows/types/basic.py", line 225, in _missing_
> new = int_type.__new__(cls, value)
> TypeError: int() argument must be a string, a bytes-like object or a real number, not 'tuple'
I know snap isn’t officially supported but when I first installed HA on Ubuntu that’s the only method I could find that didn’t involve a lot of extra work, so I’m sticking with that for now. At some point I’ll move to a RPi.
