for example I have a script (from the GUI) like that:
description: “”
- platform: device
domain: mqtt
device_id: 6ac2c63a8a95fb8a7dc47e206291a131
type: action
subtype: 1_single
discovery_id: 0x70ac08fffe3f5763 action_1_single
condition: []
action: - type: toggle
device_id: 743262f3ae0abb8ef854e1da316a50dc
entity_id: light.t_esseng_1
domain: light
mode: single
When I start the script from HA it works. (And it used to work with the switch).
The switch is still running:
debug 2023-06-03 08:00:57Received Zigbee message from ‘Taster_Kueche’, type ‘raw’, cluster ‘genOnOff’, data ‘{“data”:[1,60,253,0],“type”:“Buffer”}’ from endpoint 1 with groupID 0
info 2023-06-03 08:00:57MQTT publish: topic ‘zigbee2mqtt/Taster_Kueche’, payload ‘{“action”:“single”,“battery”:100,“last_seen”:“2023-06-03T08:01:07+02:00”,“linkquality”:69,“voltage”:3000}’
The device_id is correct. Is it possible to try the entity id instead??
I would be really gratefull for any help. Thanks
