### Bug description
I have successfully paired two Tuya compatible switches (th…e brand is Zemismart) that show the problem that whenever I toggle one gang in HA, all gangs get toggled. Switching single gangs manually on the switches works fine. Quirks are loaded but do not seem to fix it for these models.
### Steps to reproduce
Toggle any one gang of the switch in HA dashboard and all gangs will be toggled.
### Expected behavior
I'd expect to be able to toggle each gang separately.
### Screenshots/Video
_No response_
### Device signature
<details><summary>Device signature</summary>
**2-gang**
```json
Nwk: 0x8b27
Device Type: EndDevice
LQI: 54
RSSI: Unknown
Last Seen: 2023-05-01T10:53:52
Power Source: Battery or Unknown
Quirk: zhaquirks.tuya.ts001x.TuyaDoubleNoNeutralSwitch_2
**3-gang**
```json
Nwk: 0x4d27
LQI: 51
RSSI: Unknown
Last Seen: 2023-05-01T10:58:18
Quirk: zhaquirks.tuya.ts001x.TuyaTripleNoNeutralSwitch_2
</details>
### Diagnostic information
<details><summary>Diagnostic information</summary>
**2-gang**
```json
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.4.6",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.10",
"docker": true,
"arch": "aarch64",
"timezone": "Asia/Manila",
"os_name": "Linux",
"os_version": "6.1.21-v8",
"supervisor": "2023.04.1",
"host_os": "Home Assistant OS 10.1",
"docker_version": "23.0.3",
"chassis": "embedded",
"run_as_root": true
"custom_components": {},
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"after_dependencies": [
"onboarding",
"usb"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"config_flow": true,
"dependencies": [
"file_upload"
"documentation": "https://www.home-assistant.io/integrations/zha",
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"requirements": [
"bellows==0.35.1",
"pyserial==3.5",
"pyserial-asyncio==0.6",
"zha-quirks==0.0.97",
"zigpy-deconz==0.20.0",
"zigpy==0.54.1",
"zigpy-xbee==0.17.0",
"zigpy-zigate==0.10.3",
"zigpy-znp==0.10.0"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"type": "_slzb-06._tcp.local.",
"name": "slzb-06*"
"is_built_in": true
"data": {
"ieee": "**REDACTED**",
"nwk": 35623,
"manufacturer": "_TZ3000_axmpdjjk",
"model": "TS0012",
"name": "_TZ3000_axmpdjjk TS0012",
"quirk_applied": true,
"quirk_class": "zhaquirks.tuya.ts001x.TuyaDoubleNoNeutralSwitch_2",
"manufacturer_code": 4417,
"power_source": "Battery or Unknown",
"lqi": 72,
"rssi": null,
"last_seen": "2023-05-01T11:07:07",
"available": true,
"device_type": "EndDevice",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": 260,
"device_type": "0x0100",
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006"
"out_clusters": [
"0x0019"
"2": {
"profile_id": 260,
"in_clusters": [
"0x0004",
"0x0005",
"0x0006"
"out_clusters": []
"active_coordinator": false,
"entities": [
"entity_id": "button.tz3000_axmpdjjk_ts0012_identify",
"entity_id": "light.tz3000_axmpdjjk_ts0012_light",
"entity_id": "light.tz3000_axmpdjjk_ts0012_light_2",
"neighbors": [],
"routes": [],
"endpoint_names": [
"name": "ON_OFF_LIGHT"
"user_given_name": "Terrace ceiling lights",
"device_reg_id": "326f480d402d631299898909e8b2ef98",
"area_id": "terrace",
"cluster_details": {
"1": {
"device_type": {
"name": "ON_OFF_LIGHT",
"id": 256
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0004": {
"attribute_name": "manufacturer",
"value": "_TZ3000_axmpdjjk"
"0x0005": {
"attribute_name": "model",
"value": "TS0012"
"unsupported_attributes": {}
"0x0003": {
"endpoint_attribute": "identify",
"attributes": {},
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {
"0x0000": {
"attribute_name": "on_off",
"value": 0
"0x4001": {
"attribute_name": "on_time",
"value": 0
"0x4002": {
"attribute_name": "off_wait_time",
"value": 0
"0x8001": {
"attribute_name": "backlight_mode",
"value": 1
"0x8002": {
"attribute_name": "power_on_state",
"value": 2
"out_clusters": {
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {},
"2": {
"device_type": {
"id": 256
"profile_id": 260,
"in_clusters": {
"0x0004": {
"attributes": {},
"0x0005": {
"attributes": {},
"0x0006": {
"attributes": {
"0x0000": {
"value": 0
"0x4001": {
"value": 0
"0x4002": {
"value": 0
"out_clusters": {}
**3-gang**
```json
"home_assistant": {
"dev": false,
"hassio": true,
"docker": true,
"arch": "aarch64",
"os_name": "Linux",
"run_as_root": true
"domain": "zha",
"onboarding",
"usb"
"codeowners": [
"@dmulcahey",
"@adminiuga",
"@puddly"
"dependencies": [
"file_upload"
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp"
"requirements": [
"bellows==0.35.1",
"pyserial==3.5",
"zigpy==0.54.1",
"zigpy-znp==0.10.0"
"usb": [
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"vid": "1A86",
"pid": "55D4",
"known_devices": [
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1CF1",
"pid": "0030",
"known_devices": [
"Conbee II"
"vid": "10C4",
"pid": "8A2A",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"known_devices": [
"zeroconf": [
"name": "tube*"
"name": "*zigate*"
"name": "*zigstar*"
"name": "slzb-06*"
"is_built_in": true
"data": {
"nwk": 19751,
"manufacturer": "_TZ3000_liixymgk",
"model": "TS0013",
"name": "_TZ3000_liixymgk TS0013",
"quirk_class": "zhaquirks.tuya.ts001x.TuyaTripleNoNeutralSwitch_2",
"lqi": 54,
"rssi": null,
"last_seen": "2023-05-01T11:05:23",
"available": true,
"signature": {
"endpoints": {
"1": {
"profile_id": 260,
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006"
"out_clusters": [
"0x0019"
"2": {
"profile_id": 260,
"in_clusters": [
"0x0004",
"0x0005",
"0x0006"
"out_clusters": []
"3": {
"profile_id": 260,
"in_clusters": [
"0x0004",
"0x0005",
"0x0006"
"out_clusters": []
"entities": [
"entity_id": "button.ceiling_lights_identify",
"entity_id": "light.ceiling_lights_light",
"entity_id": "light.ceiling_lights_light_2",
"entity_id": "light.ceiling_lights_light_3",
"neighbors": [],
"routes": [],
"endpoint_names": [
"user_given_name": "Ceiling Lights",
"device_reg_id": "95c67b9bdb58f85b99089889cc9ad535",
"area_id": "living_room",
"1": {
"device_type": {
"id": 256
"profile_id": 260,
"in_clusters": {
"0x0000": {
"attributes": {
"0x0004": {
"value": "_TZ3000_liixymgk"
"0x0005": {
"value": "TS0013"
"0x0003": {
"attributes": {},
"0x0004": {
"attributes": {},
"0x0005": {
"attributes": {},
"0x0006": {
"attributes": {
"0x0000": {
"value": 0
"0x4001": {
"value": 0
"0x4002": {
"value": 0
"0x8001": {
"value": 1
"0x8002": {
"value": 2
"out_clusters": {
"0x0019": {
"attributes": {},
"2": {
"device_type": {
"id": 256
"profile_id": 260,
"in_clusters": {
"0x0004": {
"attributes": {},
"0x0005": {
"attributes": {},
"0x0006": {
"attributes": {
"0x0000": {
"value": 0
"0x4001": {
"value": 0
"0x4002": {
"value": 0
"out_clusters": {}
"3": {
"device_type": {
"id": 256
"profile_id": 260,
"in_clusters": {
"0x0004": {
"attributes": {},
"0x0005": {
"attributes": {},
"0x0006": {
"attributes": {
"0x0000": {
"value": 0
"0x4001": {
"value": 0
"0x4002": {
"value": 0
"out_clusters": {}
</details>
### Logs
_No response_
### Additional information
_No response_
