Zigbee T&H sensor not displaying any entities
I’m trying to add a T&H sensor with ZHA, the device is found but I only am able to see the entities that should come from this device. It only shows the LQI and RSSI.
Diagnostics show the following.
Anyone experiencing the same issues or suggestions on how to solve this? I already removed and added the device multiple times, I rebooted HA after every step.
"data": {
    "ieee": "**REDACTED**",
    "nwk": 24922,
    "manufacturer": "_TZE200_vvmbj46n",
    "model": "TS0601",
    "name": "_TZE200_vvmbj46n TS0601",
    "quirk_applied": false,
    "quirk_class": "zigpy.device.Device",
    "manufacturer_code": 4417,
    "power_source": "Battery or Unknown",
    "lqi": 152,
    "rssi": -62,
    "last_seen": "2023-10-05T18:32:18",
    "available": true,
    "device_type": "EndDevice",
    "signature": {
      "node_descriptor": "NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)",
      "endpoints": {
        "1": {
          "profile_id": "0x0104",
          "device_type": "0x0051",
          "input_clusters": [
            "0x0000",
            "0x0004",
            "0x0005",
            "0xef00"
          "output_clusters": [
            "0x000a",
            "0x0019"
      "model": "TS0601"
    "active_coordinator": false,
    "entities": [],
    "neighbors": [],
    "routes": [],
    "endpoint_names": [
        "name": "SMART_PLUG"
    "user_given_name": "T&H sensor",
    "device_reg_id": "827edefba6fec34e217c665438f6c413",
    "area_id": "living",
    "cluster_details": {
      "1": {
        "device_type": {
          "name": "SMART_PLUG",
          "id": 81
        "profile_id": 260,
        "in_clusters": {
          "0x0004": {
            "endpoint_attribute": "groups",
            "attributes": {},
            "unsupported_attributes": {}
          "0x0005": {
            "endpoint_attribute": "scenes",
            "attributes": {},
          "0xef00": {
            "endpoint_attribute": null,
            "attributes": {},
          "0x0000": {
            "endpoint_attribute": "basic",
            "attributes": {
              "0x0001": {
                "attribute_name": "app_version",
                "value": 72
              "0x0004": {
                "attribute_name": "manufacturer",
                "value": "_TZE200_vvmbj46n"
              "0x0005": {
                "attribute_name": "model",
                "value": "TS0601"
        "out_clusters": {
          "0x0019": {
            "endpoint_attribute": "ota",
            "attributes": {},
          "0x000a": {
            "endpoint_attribute": "time",
            "attributes": {},
Tuya without a quirk isn’t going to work.
Looks like there is an open support request. [Device Support Request] NOUS E6 TS0601 _TZE200_nnrfa68v · Issue #1702 · zigpy/zha-device-handlers · GitHub
Best to raise the issue over there to get it merged.
Thanks. I found the quirk for my device there. Seems to be working now!
Hi, did you manage to set date/time in it?
I’ve seen the Time cluster when viewing device in HA with the quirk.
But reading/writing its attributes didn’t give any result.
Can’t see any command within the cluster either.
Thanks.
Hi @eugene.d I just solved! (Or maybe I rediscovered) Here is the code I used to get the time and date into display:
The original code I’ve found at https://github.com/zigpy/zha-device-handlers/issues/2732 Used as base the code from richardcc and later I’ve found this website https://smarthomescene.com/reviews/zigbee-temperature-humidity-sensor-with-a-screen-sz-t04-review/ Where I took the functions for date time.
Anyway, here is my modified version I’ve been telling at the beginning.
"""Tuya temp and humidity sensors."""
from typing import Any, Dict
import zigpy.types as t
import datetime
from zigpy.profiles import zha
from zigpy.quirks import CustomDevice
from zigpy.zcl import foundation
from zigpy.zcl.clusters.general import Basic, Groups, Ota, Scenes, Time
from zigpy.zcl.clusters.measurement import (
    RelativeHumidity,
    SoilMoisture,
    TemperatureMeasurement,
from zhaquirks.const import (
    DEVICE_TYPE,
    ENDPOINTS,
    INPUT_CLUSTERS,
    MODELS_INFO,
    OUTPUT_CLUSTERS,
    PROFILE_ID,
    SKIP_CONFIGURATION,
from zhaquirks.tuya import TuyaLocalCluster, TuyaPowerConfigurationCluster2AAA, TuyaTimePayload
from zhaquirks.tuya.mcu import DPToAttributeMapping, TuyaMCUCluster
TUYA_SET_TIME = 0x24
class TuyaTemperatureMeasurement(TemperatureMeasurement, TuyaLocalCluster):
    """Tuya local TemperatureMeasurement cluster."""
class TuyaSoilMoisture(SoilMoisture, TuyaLocalCluster):
    """Tuya local SoilMoisture cluster with a device RH_MULTIPLIER
factor if required."""
class TuyaRelativeHumidity(RelativeHumidity, TuyaLocalCluster):
    """Tuya local RelativeHumidity cluster with a device RH_MULTIPLIER
factor."""
    def update_attribute(self, attr_name: str, value: Any) -> None:
        """Apply a correction factor to value."""
        if attr_name == "measured_value":
            value = value * (
                self.endpoint.device.RH_MULTIPLIER
                if hasattr(self.endpoint.device, "RH_MULTIPLIER")
                else 100
        return super().update_attribute(attr_name, value)
class TemperatureHumidityManufCluster(TuyaMCUCluster):
    """Tuya Manufacturer Cluster with Temperature and Humidity data points."""
    dp_to_attribute: Dict[int, DPToAttributeMapping] = {
        1: DPToAttributeMapping(
            TuyaTemperatureMeasurement.ep_attribute,
            "measured_value",
            converter=lambda x: x * 10,  # decidegree to centidegree
        2: DPToAttributeMapping(
            TuyaRelativeHumidity.ep_attribute,
            "measured_value",
            # converter=lambda x: x * 10,  --> move conversion to TuyaRelativeHumidity cluster
        4: DPToAttributeMapping(
            TuyaPowerConfigurationCluster2AAA.ep_attribute,
            "battery_percentage_remaining",
            converter=lambda x: x * 2,  # double reported percentage
    set_time_offset = 1970
    set_time_local_offset = 1970
    data_point_handlers = {
        1: "_dp_2_attr_update",
        2: "_dp_2_attr_update",
        4: "_dp_2_attr_update",
    def handle_set_time_request(self, sequence_number: t.uint16_t) -> foundation.Status:
        payload = TuyaTimePayload()
        utc_now = datetime.datetime.utcnow()
        now = datetime.datetime.now()
        offset_time = datetime.datetime(self.set_time_offset, 1, 1)
        offset_time_local = datetime.datetime(self.set_time_local_offset, 1, 1)
        utc_timestamp = int((utc_now - offset_time).total_seconds())
        local_timestamp = int((now - offset_time).total_seconds())
        payload.extend(utc_timestamp.to_bytes(4, "big", signed=False))
        payload.extend(local_timestamp.to_bytes(4, "big", signed=False))
        self.create_catching_task(
            self.command(TUYA_SET_TIME, payload, manufacturer=foundation.ZCLHeader.NO_MANUFACTURER_ID, expect_reply=False)
        return foundation.Status.SUCCESS
class TemperatureHumidityBatteryStatesManufCluster(TuyaMCUCluster):
points. Battery states 25, 50 and 100%."""
        1: TemperatureHumidityManufCluster.dp_to_attribute[1],
        2: TemperatureHumidityManufCluster.dp_to_attribute[2],
        3: DPToAttributeMapping(
            converter=lambda x: {0: 25, 1: 50, 2: 100}[x],  # double reported percentage
        3: "_dp_2_attr_update",
class TuyaTempHumiditySensor(CustomDevice):
    """Custom device representing tuya temp and humidity sensor with
e-ink screen."""
    # RelativeHumidity multiplier
    RH_MULTIPLIER = 100
    signature = {
        # <SimpleDescriptor endpoint=1, profile=260, device_type=81
        # device_version=1
        # input_clusters=[4, 5, 61184, 0]
        # output_clusters=[25, 10]>
        MODELS_INFO: [
            ("_TZE200_bjawzodf", "TS0601"),
            ("_TZE200_zl1kmjqx", "TS0601"),
            ("_TZE200_vvmbj46n", "TS0601"),
        ENDPOINTS: {
            1: {
                PROFILE_ID: zha.PROFILE_ID,
                DEVICE_TYPE: zha.DeviceType.SMART_PLUG,
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    TemperatureHumidityManufCluster.cluster_id,
                OUTPUT_CLUSTERS: [Ota.cluster_id, Time.cluster_id],
    replacement = {
        SKIP_CONFIGURATION: True,
        ENDPOINTS: {
            1: {
                DEVICE_TYPE: zha.DeviceType.TEMPERATURE_SENSOR,
                INPUT_CLUSTERS: [
                    TemperatureHumidityManufCluster,  # Single bus for temp, humidity, and battery
                    TuyaTemperatureMeasurement,
                    TuyaRelativeHumidity,
class TuyaTempHumiditySensor_Square(CustomDevice):
e-ink screen."""
    # RH_MULTIPLIER = 100
    signature = {
        MODELS_INFO: [
            ("_TZE200_a8sdabtg", "TS0601"),  # Variant without screen, round
            ("_TZE200_qoy0ekbd", "TS0601"),
            ("_TZE200_znbl8dj5", "TS0601"),
        ENDPOINTS: {
            1: {
                # "profile_id": 260, "device_type": "0x0302",
                # "in_clusters": ["0x0000","0x0001","0x0402","0x0405"],
                # "out_clusters": ["0x000a","0x0019"]
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    TuyaPowerConfigurationCluster2AAA.cluster_id,
                    TemperatureMeasurement.cluster_id,
                    RelativeHumidity.cluster_id,
    replacement = {
        ENDPOINTS: {
            1: {
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
class TuyaTempHumiditySensorVar03(CustomDevice):
    """Tuya temp and humidity sensor (variation 03)."""
    signature = {
        # "device_type": "0x0051",
        # "in_clusters": ["0x0000","0x0004","0x0005","0xef00"],
        MODELS_INFO: [
            ("_TZE200_qyflbnbj", "TS0601"),
            ("_TZE200_utkemkbs", "TS0601"),
        ENDPOINTS: {
            1: {
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
    replacement = {
        ENDPOINTS: {
            1: {
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
class TuyaTempHumiditySensorVar04(CustomDevice):
    """Tuya temp and humidity sensor (variation 04)."""
    signature = {
        MODELS_INFO: [
            ("_TZE200_yjjdcqsq", "TS0601"),
            ("_TZE200_9yapgbuv", "TS0601"),
        ENDPOINTS: {
            1: {
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
    replacement = {
        ENDPOINTS: {
            1: {
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    TemperatureHumidityBatteryStatesManufCluster,
class SoilManufCluster(TuyaMCUCluster):
        5: DPToAttributeMapping(
            "measured_value",
            converter=lambda x: x * 100,
            TuyaSoilMoisture.ep_attribute,
            "measured_value",
        15: DPToAttributeMapping(
        5: "_dp_2_attr_update",
        15: "_dp_2_attr_update",
class TuyaSoilSensor(CustomDevice):
    signature = {
        MODELS_INFO: [
            ("_TZE200_myd45weu", "TS0601"),
            ("_TZE200_ga1maeof", "TS0601"),
        ENDPOINTS: {
            1: {
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
    replacement = {
        ENDPOINTS: {
            1: {
                INPUT_CLUSTERS: [
                    Basic.cluster_id,
                    Groups.cluster_id,
                    Scenes.cluster_id,
                    SoilManufCluster,
                    TuyaSoilMoisture,
Also there is this other solution, but haven’t tried yet:
But later I’ve found this code [Device Support Request] NOUS E6 TS0601 _TZE200_nnrfa68v · Issue #1702 · zigpy/zha-device-handlers · GitHub (Haven’t tried)
