ZigBee temp/humid with time
hi can anyone recommend a temp/humid sensor with time, that is compatible with zha
This version is a good option as well, I have it setup in my lounge room currently and its been working solid for a few months now. I have its backplate mounted to the center wall with double sided tape then it just attaches via magnet to its plate for easy battery swap come time.
Thanks for the suggestions but it ideally needs a display with time, temp and humid
There are some listings here that may be of interest:
https://www.aliexpress.com/w/wholesale-zigbee-clock.html
Specifically:
https://www.aliexpress.com/item/1005006841998324.html
and
https://www.aliexpress.com/item/1005005464553349.html
Others that have had some experience with these ones may post up, I gen stay away from tuya branded items but as long as its not tuya wifi but tuya zigbee it should be fine to use.
does anyone have anyone have any experience with any of these
I’ve had really good luck with Thirdreality Zigbee products - specifically theses - Amazon.com: THIRDREALITY Zigbee Temperature and Humidity Sensor 2 Pack, Digital LCD Display, ZigBee Hub Required, App Records, Remote Monitoring and Smart Home Automation, AAA Batteries Included : Appliances
Unfortunately they don’t show the time, but they do display temperature and humidity and work great with HA.
@escapedgoat Have you had any issues with the display showing one value for temperature while the HA entity reports something completely different?
can anyone do me a huge favour and go through the link and let me know if they’ve tried any with zha
