Hello! I have the end device TS000F from Mhcozy here. Device pairs with my ZHA integration. But it is detected only as light - what is obviously the switch of this device.
However, the TS000F also is a temperature sensor. This is the diagnostics file of the device:
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2024.7.2",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.12.4",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Vienna",
"os_name": "Linux",
"os_version": "6.6.33-haos",
"supervisor": "2024.06.2",
"host_os": "Home Assistant OS 12.4",
"docker_version": "26.1.4",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"awattar_energy_cost": {
"documentation": "https://github.com/TheBrain8791/ha_awattar",
"version": "0.1.0",
"requirements": [
"bs4"
"smartlife": {
"documentation": "https://www.home-assistant.io/integrations/smartlife",
"version": "0.1.0",
"requirements": [
"tuya-device-sharing-sdk==0.2.0"
"hacs": {
"documentation": "https://hacs.xyz/docs/configuration/start",
"version": "1.34.0",
"requirements": [
"aiogithubapi>=22.10.1"
"localtuya": {
"documentation": "https://github.com/rospogrigio/localtuya/",
"version": "5.2.1",
"requirements": []
"integration_manifest": {
"domain": "zha",
"name": "Zigbee Home Automation",
"after_dependencies": [
"onboarding",
"usb"
"codeowners": [
"dmulcahey",
"adminiuga",
"puddly",
"TheJulianJES"
"config_flow": true,
"dependencies": [
"file_upload"
"documentation": "https://www.home-assistant.io/integrations/zha",
"iot_class": "local_polling",
"loggers": [
"aiosqlite",
"bellows",
"crccheck",
"pure_pcapy3",
"zhaquirks",
"zigpy",
"zigpy_deconz",
"zigpy_xbee",
"zigpy_zigate",
"zigpy_znp",
"universal_silabs_flasher"
"requirements": [
"bellows==0.39.1",
"pyserial==3.5",
"zha-quirks==0.0.117",
"zigpy-deconz==0.23.2",
"zigpy==0.64.1",
"zigpy-xbee==0.20.1",
"zigpy-zigate==0.12.1",
"zigpy-znp==0.12.2",
"universal-silabs-flasher==0.0.20",
"pyserial-asyncio-fast==0.11"
"usb": [
"vid": "10C4",
"pid": "EA60",
"description": "*2652*",
"known_devices": [
"slae.sh cc2652rb stick"
"vid": "10C4",
"pid": "EA60",
"description": "*slzb-07*",
"known_devices": [
"smlight slzb-07"
"vid": "1A86",
"pid": "55D4",
"description": "*sonoff*plus*",
"known_devices": [
"sonoff zigbee dongle plus v2"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"sonoff zigbee dongle plus"
"vid": "10C4",
"pid": "EA60",
"description": "*tubeszb*",
"known_devices": [
"TubesZB Coordinator"
"vid": "1A86",
"pid": "7523",
"known_devices": [
"vid": "1A86",
"pid": "7523",
"description": "*zigstar*",
"known_devices": [
"ZigStar Coordinators"
"vid": "1CF1",
"pid": "0030",
"description": "*conbee*",
"known_devices": [
"Conbee II"
"vid": "0403",
"pid": "6015",
"known_devices": [
"Conbee III"
"vid": "10C4",
"pid": "8A2A",
"description": "*zigbee*",
"known_devices": [
"Nortek HUSBZB-1"
"vid": "0403",
"pid": "6015",
"description": "*zigate*",
"known_devices": [
"ZiGate+"
"vid": "10C4",
"pid": "EA60",
"known_devices": [
"ZiGate"
"vid": "10C4",
"pid": "8B34",
"description": "*bv 2010/10*",
"known_devices": [
"Bitron Video AV2010/10"
"zeroconf": [
"type": "_esphomelib._tcp.local.",
"name": "tube*"
"type": "_zigate-zigbee-gateway._tcp.local.",
"name": "*zigate*"
"type": "_zigstar_gw._tcp.local.",
"name": "*zigstar*"
"type": "_uzg-01._tcp.local.",
"name": "uzg-01*"
"type": "_slzb-06._tcp.local.",
"name": "slzb-06*"
"type": "_xzg._tcp.local.",
"name": "xzg*"
"type": "_czc._tcp.local.",
"name": "czc*"
"is_built_in": true
"setup_times": {
"null": {
"setup": 5.867995787411928e-05
"01J1YJKYR9QZYJ7ZKE1TH4GE2V": {
"config_entry_setup": 5.045233323937282
"data": {
"ieee": "**REDACTED**",
"nwk": 49786,
"manufacturer": "_TZ3218_7fiyo3kv",
"model": "TS000F",
"name": "_TZ3218_7fiyo3kv TS000F",
"quirk_applied": false,
"quirk_class": "zigpy.device.Device",
"quirk_id": null,
"manufacturer_code": 4417,
"power_source": "Mains",
"lqi": 248,
"rssi": -81,
"last_seen": "2024-07-12T15:22:44",
"available": true,
"device_type": "Router",
"signature": {
"node_descriptor": "NodeDescriptor(logical_type=<LogicalType.Router: 1>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.FullFunctionDevice|MainsPowered|RxOnWhenIdle|AllocateAddress: 142>, manufacturer_code=4417, maximum_buffer_size=66, maximum_incoming_transfer_size=66, server_mask=10752, maximum_outgoing_transfer_size=66, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False)",
"endpoints": {
"1": {
"profile_id": "0x0104",
"device_type": "0x0100",
"input_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0xe000",
"0xe001",
"0xef00"
"output_clusters": [
"0x000a",
"0x0019"
"242": {
"profile_id": "0xa1e0",
"device_type": "0x0061",
"input_clusters": [],
"0x0021"
"model": "TS000F"
"active_coordinator": false,
"entities": [
"entity_id": "button.temperatur_pool_zigbee_identifizieren",
"entity_id": "light.temperatur_pool_zigbee_licht",
"entity_id": "sensor.tz3218_7fiyo3kv_ts000f_rssi",
"entity_id": "sensor.tz3218_7fiyo3kv_ts000f_lqi",
"entity_id": "update.temperatur_pool_zigbee_firmware",
"neighbors": [],
"routes": [],
"endpoint_names": [
"name": "ON_OFF_LIGHT"
"name": "PROXY_BASIC"
"user_given_name": "temperatur.pool.zigbee",
"device_reg_id": "e812a5bb22800e1fe3778c8774ae8d40",
"area_id": "terrasse",
"cluster_details": {
"1": {
"device_type": {
"name": "ON_OFF_LIGHT",
"id": 256
"profile_id": 260,
"in_clusters": {
"0x0000": {
"endpoint_attribute": "basic",
"attributes": {
"0x0004": {
"attribute_name": "manufacturer",
"value": "_TZ3218_7fiyo3kv"
"0x0005": {
"attribute_name": "model",
"value": "TS000F"
"unsupported_attributes": {}
"0x0003": {
"endpoint_attribute": "identify",
"attributes": {},
"0x0004": {
"endpoint_attribute": "groups",
"attributes": {},
"0x0005": {
"endpoint_attribute": "scenes",
"attributes": {},
"0x0006": {
"endpoint_attribute": "on_off",
"attributes": {
"0x0000": {
"attribute_name": "on_off",
"value": 0
"0x4003": {
"attribute_name": "start_up_on_off"
"0xe001": {
"endpoint_attribute": null,
"attributes": {},
"0xe000": {
"attributes": {},
"0xef00": {
"attributes": {},
"out_clusters": {
"0x000a": {
"endpoint_attribute": "time",
"attributes": {},
"0x0019": {
"endpoint_attribute": "ota",
"attributes": {
"0x0002": {
"attribute_name": "current_file_version",
"value": 80
"242": {
"device_type": {
"name": "PROXY_BASIC",
"id": 97
"profile_id": 41440,
"in_clusters": {},
"out_clusters": {
"0x0021": {
"endpoint_attribute": "green_power",
"attributes": {},
Any idea how I can get the temperature sensor entity?
