I am running zigbee on a seeed xiao_ble. I am using zigbee2mqtt. Everything works as expected except for the time component.
esphome:
friendly_name: nrf light sensor
nrf52:
board: xiao_ble
logger:
level: VERBOSE
zigbee:
model: “XIAO-LuxSensor-1”
time:
- platform: zigbee
On boot I see the incorrect time in the logs:
[11:41:39][C][zigbee:227]: Zigbee
[11:41:39][C][zigbee:227]: Wipe on boot: NO
[11:41:39][C][zigbee:227]: Device is joined to the network: YES
[11:41:39][C][zigbee:227]: Sleep time: 1s
[11:41:39][C][zigbee:227]: RX ON when idle: YES
[11:41:39][C][zigbee:227]: Current channel: 11
[11:41:39][C][zigbee:227]: Current page: 0
[11:41:39][C][zigbee:227]: Sleep threshold: 20ms
[11:41:39][C][zigbee:227]: Role: end device
[11:41:39][C][zigbee:227]: Long addr: 0xf4ce365d89e48318
[11:41:39][C][zigbee:227]: Short addr: 0x1388
[11:41:39][C][zigbee:227]: Long pan id: 0xa57b2faa8c3b7210
[11:41:39][C][zigbee:227]: Short pan id: 0x0263
[11:41:40][C][zigbee.time:033]: Zigbee Time
[11:41:40][C][zigbee.time:033]: Endpoint: 1
[11:41:40][C][time:055]: Current time: 1969-12-31 23:59:59
I I update the time via a mqtt message to zigbee2mqtt, I see the following in the logs:
[11:42:30][I][zigbee:114][0x20001f48]: zcl_device_cb id 0, cluster_id 10, attr_id 0, endpoint: 1
[11:42:30][I][zigbee.time:064][0x20001f48]: Synchronize time to 1786732950
[11:42:30][D][time:104]: Synchronized time: 1969-12-31 23:59:59
[11:42:30][D][zigbee.time:082][0x20001f48]: Zcl_device_cb_ status: 0
From the logs it appears that zigbee.time receives the correct unix time stamp of 1786732950. However, the synchronized time is still incorrect. zigbee.time appears to report that there were no issues (status: 0).
The zigbee2mqtt logs indicate that the mqtt message was sent and received. The problem appears to be between the zigbee.time component and the time component. I have tried restart/reset/reboot the various participating addons/integrations/ha etc …
Any thoughts?
