Zigbee Tradfri control almost anything
Hi.
I know probably there are many project using Tradfri “chips” controls led dimmers, but i did not find any that use them not only for lights.
So here it is: Tradfri (and arduino) as a servo motor controller (or any other devices, depends on your creativity).
Tradfri Zigbee use pwm to control brightness of leds, to use that, we need to progam arduino to counts pwm signals and check on/off status, below arduino code and short movie of proof of concept.
If you wanna use it, have fun.
byte PWM_PIN = 2;  //output from transoptor
int status_on_off; // on/off check value
int pwm_value;    //counted pwm signal (new)
int pwm_value_old; //counted pwm signal (old)
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
void setup() {
  pinMode(PWM_PIN, INPUT);
  Serial.begin(115200);
  myservo.attach(9);  // pin 9 as servo controler
void loop() {
  pwm_value = pulseIn(PWM_PIN, HIGH); //count pwm
  pwm_value = map(pwm_value, 0, 1500, 0, 180); //map pwm to servo value
  delay(100);  //short delay
  if (pwm_value != pwm_value_old) //check if there was a change between old and new readings
        delay(1000); //longer delay
        pwm_value = pulseIn(PWM_PIN, HIGH);  //another readings to avoid jumps between statuses
        pwm_value = map(pwm_value, 0, 1500, 0, 180); //another map pwm to servo value
        status_on_off = digitalRead(PWM_PIN);  // reading if pwm pin is high or low,
                                               // for "full" on and off pwn will be always 0,
                                               // so value HIGH or LOW value must be check
        Serial.println(status_on_off);
     if (pwm_value == 0)
            if (status_on_off == 0)
               Serial.println("OFF");
               myservo.write(0);
            if (status_on_off == 1)
               Serial.println("ON");
               myservo.write(180);
     if (pwm_value != 0)
          Serial.println(pwm_value);
          myservo.write(pwm_value);
     pwm_value_old = pwm_value;
Short movie: https://drive.google.com/file/d/10r6yKrR8kec0avZwcwlQ73HwqAnZaf_K/view
What tradfri device is that? They make a lot of stuff.
It can be LED bulb GU10 400 lumen or LED bulb E27 806 lumen or any other Ikea TRÅDFRI bulb without spectrum or color change.
(Btw; one works flawless already as receiver for ’ diy smart curtains’)
Thank you very much for sharing! Done the same. Everything works great. Going to make ventilation valve control device.
