All, I have sucessfully integrated 3 different Zigbee TRVs, but I have no idea how to control/automate them using Home Assistant, maybe someone can get me there?
My Devices:
Brand Zigbee info
Vale ts0601_trv_zonnsmart.ZonnsmartTV01_ZG
Tuya/Moes ts0601_trv_moes.MoesHY368_Type1
Nedis ts0601_trv_siterwell.SiterwellGS361_Type2
I have successfully installed the custom quirks in the configuration.yaml
But there is no single valve.xxx entity, there are entites for climate.xxx and sensors.xxx and switch.xxx but I have no idea, what entity I can use for automating the TRVs. I can even not use an automation blueprint like Better Thermostat among others because the expected fields do not match with available entities.
I only want to decrease the temperatures at night and increase it at daytime.
What I found out using the Developer Tools->Actions is this and it works and I can insert this into an automation, but this is not the way I thought I could use HA for (not very comfortable)
action: climate.set_temperature
hvac_mode: auto
temperature: 21.5
device_id: d9b78fe80e79038cc93d683dc9ebae15
Maybe I am not familiar enough with HA Automations, but as far as I know for now I have to write a script for each action, so one for every point in time when the TRV has to be set to a different value or state, in the morning, over the day, in the evening and nights. I have to check for weekdays and weekdays and so forth. I was expecting the possibility to define all this in one script (per TRV, I have more of them).
But the point is, that there are automation blueprints available and they expect entities which are not available with my TRVs, e.g. “valve.xxx”, so I cannot use them so far - or I am missing anything or doing something wrong? So if anyone who uses one of these TRVs, could he/she post how he/she is using it with automations or what blueprints you are using and how?
My bad, I thought you were asking how to control them:
