Zigbee TV remote
Hi all,
I ca bassicly controll all my devices (TV, Reciever, Android TV) through HA. Selecting inputs, changing chanell, volume etc, all works.
I have 3 remotes laying around now and I want to get rid of them. I’m looking for a TV remote which doesn`t send our a IR signal or something but only button presses to the zigbee network.
I can then match these button presses to automations in HA to controll whatever device I want with that button press.
Does anybody know if there is a tv remote availible? I can find enough remotes but these are just for switching on lights etc.
Some remotes support zWave but I haven’t come across any Zigbee based TV-remotes.
However the Logitech Harmony has a working HA-integration.
Yes I know, but Harmony is bassicly EOL and you need a working Logictec server for this to work. So when Logitec desides to stop supporting them I`m done…
That’s not correct, you only need to be online for the initial device selection & configuration.
After that the Harmony works locally (unless you want to modify the setup)
Hmm… and can you program every button the way you want? For example connect a script to a button press in home assistant?
