Yeah, the problem with the Scenic stuff is that it’s just a smart switch/button you can tape to the wall (or fit in the Gira system55) and will only wirelessly switch your smart lights. You cannot use it to make a dumb bulb smart
Yep, you’re right. But it would work for me as I was looking for an option to integrate next to my bed for scenes. It’s a light switch and two window shutter switches, that’s why I am searching for something comparable with Gira. I could switch the light bulbs in the night lights with Zigbee ones.
So, I have installed it and what to say. Works flawless, fits perfect in the Gira E55 series.
I needed a few tries in swtichting the protocol, but once done, it was easily connected to Z2M. Only downside is that you can not control the LEDs indivitually, so either all on, or all off.
But I can recommend this to evreyone looking for a solution for their switches with the standard 55mm frame.
