Zigbee with Conbee stick: zha in configuration.yaml or deconz addon in hassio
I am a bit lost here. I want to use a Conbee stick on my Raspberry Pi 3B. How do I set it up?
  • add something like this to my configuration.yaml and expect things to work
# zigbee
zha:
  usb_path: /dev/ttyUSB2
  database_path: /config/zigbee.db
  radio_type: deconz
  • install the deconz addon for hassio
    Or will both work?
You can only use on at a time since the hardware channel can only be used by a single application at once and the pairing system is different as well
Ok, so both will work but only one can be implemented?
Yes, I only have experience with deCONZ though so can’t really say anything about ZHA
Ok thanks! I will try one of them :slight_smile:
