Turned on full debug and waded through the lines:
First, I get three devices detected in pydeconz.deconzdevice:
- âTRADFRI wireless dimmer 4â of type lightgroup
- âDaylightâ of type daylight
- âTRADFRI wireless dimmerâ of type ZHASwitch
Of these only the daylight sensor.daylight is visible anywhere else in the logs or UI, btw the Daylight sensor has status âNot reachableâ in the Phoscon App but I see a log entry for an event change on the sensor.daylight further down.
As far as I can see the dimmer is not visible anywhere outside of pydeconz.
-f
2018-04-24 08:17:21 DEBUG (MainThread) [pydeconz.utils] Sending {} to http://127.0.0.1:8080/api/XXXXXXXXXX
2018-04-24 08:17:21 DEBUG (MainThread) [pydeconz.utils] HTTP request response: {'config': {'UTC': '2018-04-24T06:17:21', 'apiversion': '1.0.9', 'backup': {'errorcode': 0, 'status': 'idle'}, 'bridgeid': '00212EFFFF010C52', 'datastoreversion': '60', 'devicename': 'ConBee', 'dhcp': True, 'factorynew': False, 'fwversion': '0x00000000', 'gateway': '192.133.64.1', 'internetservices': {'remoteaccess': 'disconnected'}, 'ipaddress': '192.133.64.10', 'linkbutton': False, 'localtime': '2018-04-24T06:17:21', 'mac': 'bc:ae:c5:b6:80:49', 'modelid': 'deCONZ', 'name': 'admin', 'netmask': '255.255.255.0', 'networkopenduration': 60, 'panid': 54715, 'portalconnection': 'disconnected', 'portalservices': False, 'portalstate': {'communication': 'disconnected', 'incoming': False, 'outgoing': False, 'signedon': False}, 'proxyaddress': 'none', 'proxyport': 0, 'replacesbridgeid': None, 'rfconnected': True, 'starterkitid': '', 'swupdate': {'checkforupdate': False, 'devicetypes': {'bridge': False, 'lights': [], 'sensors': []}, 'notify': False, 'text': '', 'updatestate': 0, 'url': ''}, 'swupdate2': {'autoinstall': {'on': False, 'updatetime': ''}, 'bridge': {'lastinstall': '', 'state': 'noupdates'}, 'checkforupdate': False, 'install': False, 'lastchange': '', 'lastinstall': '', 'state': 'noupdates'}, 'swversion': '2.5.20', 'timeformat': '12h', 'timezone': 'Etc/GMT-2', 'uuid': 'e864fd47-abc9-43bf-b679-54a1e339abe8', 'websocketnotifyall': True, 'websocketport': 8443, 'whitelist': {'XXXXXXXXX': {'create date': '2018-04-18T19:06:08', 'last use date': '2018-04-24T06:17:21', 'name': 'pydeconz'}, 'XXXXXXXXX': {'create date': '2018-04-23T12:11:10', 'last use date': '2018-04-24T06:17:19', 'name': 'Phoscon#B1224x751'}}, 'zigbeechannel': 15}, 'groups': {'19969': {'action': {'bri': 128, 'colormode': 'hs', 'ct': 0, 'effect': 'none', 'hue': 0, 'on': True, 'sat': 128, 'xy': [0, 0]}, 'class': 'Other', 'devicemembership': ['3'], 'etag': 'c40b4b8eb89088f61832b0ecefa3f0b8', 'hidden': False, 'id': '19969', 'lights': [], 'lightsequence': [], 'multideviceids': [], 'name': 'TRADFRI wireless dimmer 4', 'scenes': [], 'state': {'all_on': False, 'any_on': False}, 'type': 'LightGroup'}}, 'lights': {}, 'resourcelinks': {}, 'rules': {}, 'schedules': {}, 'sensors': {'1': {'config': {'configured': False, 'on': True, 'sunriseoffset': 30, 'sunsetoffset': -30}, 'etag': None, 'manufacturername': 'Philips', 'modelid': 'PHDL00', 'name': 'Daylight', 'state': {'daylight': None, 'lastupdated': 'none', 'status': None}, 'swversion': '1.0', 'type': 'Daylight', 'uniqueid': '00:21:2e:ff:ff:01:0c:52-01'}, '3': {'config': {'battery': None, 'group': '19969', 'on': True, 'reachable': True}, 'ep': 1, 'etag': '2be79d676aef21536eb18f759ca06712', 'manufacturername': 'IKEA of Sweden', 'mode': 4, 'modelid': 'TRADFRI wireless dimmer', 'name': 'TRADFRI wireless dimmer', 'state': {'buttonevent': None, 'lastupdated': 'none'}, 'swversion': '1.2.248', 'type': 'ZHASwitch', 'uniqueid': '00:0b:57:ff:fe:8a:4c:6d-01-1000'}}}
2018-04-24 08:17:21 DEBUG (MainThread) [pydeconz.config] Deconz config loaded {'_apiversion': '1.0.9', '_bridgeid': '00212EFFFF010C52', '_linkbutton': False, '_modelid': 'deCONZ', '_name': 'admin', '_networkopenduration': 60, '_panid': 54715, '_swversion': '2.5.20', '_uuid': 'e864fd47-abc9-43bf-b679-54a1e339abe8', '_websocketport': 8443, '_zigbeechannel': 15}
2018-04-24 08:17:21 DEBUG (MainThread) [pydeconz.deconzdevice] TRADFRI wireless dimmer 4 created as {'_any_on': False, '_bri': 128, '_class': 'Other', '_colormode': 'hs', '_ct': 0, '_devicemembership': ['3'], '_effect': 'none', '_hidden': False, '_hue': 0, '_id': '19969', '_lights': [], '_lightsequence': [], '_multideviceids': [], '_on': True, '_reachable': True, '_sat': 128, '_scenes': {}, '_x': 0, '_y': 0, '_async_set_state_callback': <bound method DeconzSession.async_put_state of <pydeconz.DeconzSession object at 0x7f3c7124fba8>>, '_deconz_id': '/groups/19969', '_etag': 'c40b4b8eb89088f61832b0ecefa3f0b8', '_manufacturername': None, '_modelid': None, '_name': 'TRADFRI wireless dimmer 4', '_swversion': None, '_type': 'LightGroup', '_uniqueid': None, '_async_callback': []}
2018-04-24 08:17:21 DEBUG (MainThread) [pydeconz.deconzdevice] Daylight created as {'_daylight': None, '_status': None, '_battery': None, '_ep': None, '_on': True, '_reachable': None, '_sensor_class': None, '_sensor_icon': None, '_sensor_unit': None, '_deconz_id': '/sensors/1', '_etag': None, '_manufacturername': 'Philips', '_modelid': 'PHDL00', '_name': 'Daylight', '_swversion': '1.0', '_type': 'Daylight', '_uniqueid': '00:21:2e:ff:ff:01:0c:52-01', '_async_callback': []}
2018-04-24 08:17:21 DEBUG (MainThread) [pydeconz.deconzdevice] TRADFRI wireless dimmer created as {'_buttonevent': None, '_battery': None, '_ep': 1, '_on': True, '_reachable': True, '_sensor_class': None, '_sensor_icon': None, '_sensor_unit': None, '_deconz_id': '/sensors/3', '_etag': '2be79d676aef21536eb18f759ca06712', '_manufacturername': 'IKEA of Sweden', '_modelid': 'TRADFRI wireless dimmer', '_name': 'TRADFRI wireless dimmer', '_swversion': '1.2.248', '_type': 'ZHASwitch', '_uniqueid': '00:0b:57:ff:fe:8a:4c:6d-01-1000', '_async_callback': []}
