Zigbee works, but not zigbee2mqtt (whats herdsman?)
I am rather new on using HA, so please excuse me if this is explained elsewhere.
I did search first, though.
I have been using zigbee automation since the autumn, and it works nicely, but I have not been able to start zigbee2mqtt, it seems.
Here is a log :
[2025-01-06 13:40:32] debug: 	z2m: Removing old log directory '/config/zigbee2mqtt/log/2025-01-06.13-16-50'
[2025-01-06 13:40:32] info: 	z2m: Logging to console, file (filename: log.log)
[2025-01-06 13:40:32] debug: 	z2m: Loaded state from file /config/zigbee2mqtt/state.json
[2025-01-06 13:40:32] info: 	z2m: Starting Zigbee2MQTT version 2.0.0 (commit #unknown)
[2025-01-06 13:40:32] debug: 	z2m: sd-notify loaded
[2025-01-06 13:40:32] info: 	z2m: Starting zigbee-herdsman (3.2.1)
[2025-01-06 13:40:32] debug: 	z2m: Using zigbee-herdsman with settings: '"{\"network\":{\"panID\":59692,\"extendedPanID\":[74,146,128,241,209,31,173,160],\"channelList\":[11],\"networkKey\":\"HIDDEN\"},\"databasePath\":\"/config/zigbee2mqtt/database.db\",\"databaseBackupPath\":\"/config/zigbee2mqtt/database.db.backup\",\"backupPath\":\"/config/zigbee2mqtt/coordinator_backup.json\",\"serialPort\":{},\"adapter\":{\"disableLED\":false}}"'
[2025-01-06 13:40:32] debug: 	zh:adapter:discovery: Connected devices: [{"path":"/dev/ttyAMA10"},{"path":"/dev/ttyUSB0","manufacturer":"Nabu Casa","serialNumber":"e8711f0ca539ef119e1e53f454516304","pnpId":"usb-Nabu_Casa_Home_Assistant_Connect_ZBT-1_e8711f0ca539ef119e1e53f454516304-if00-port0","vendorId":"10c4","productId":"ea60"}]
[2025-01-06 13:40:32] info: 	zh:adapter:discovery: Matched adapter: {"path":"/dev/ttyUSB0","manufacturer":"Nabu Casa","serialNumber":"e8711f0ca539ef119e1e53f454516304","pnpId":"usb-Nabu_Casa_Home_Assistant_Connect_ZBT-1_e8711f0ca539ef119e1e53f454516304-if00-port0","vendorId":"10c4","productId":"ea60"} => ember: path=/dev/ttyUSB0, score=2
[2025-01-06 13:40:32] info: 	zh:ember: Using default stack config.
[2025-01-06 13:40:32] debug: 	zh:controller: Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":"HIDDEN","panID":59692,"extendedPanID":[74,146,128,241,209,31,173,160],"channelList":[11]},"serialPort":{"path":"/dev/ttyUSB0","adapter":"ember"},"adapter":{"disableLED":false},"databasePath":"/config/zigbee2mqtt/database.db","databaseBackupPath":"/config/zigbee2mqtt/database.db.backup","backupPath":"/config/zigbee2mqtt/coordinator_backup.json"}'
[2025-01-06 13:40:32] info: 	zh:ember: ======== Ember Adapter Starting ========
[2025-01-06 13:40:32] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2025-01-06 13:40:32] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-01-06 13:40:32] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2025-01-06 13:40:32] debug: 	zh:ember:uart:ash: Opening serial port with {"path":"/dev/ttyUSB0","baudRate":115200,"rtscts":false,"autoOpen":false,"parity":"none","stopBits":1,"xon":true,"xoff":true}
[2025-01-06 13:40:32] info: 	zh:ember:uart:ash: Serial port opened
[2025-01-06 13:40:32] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-01-06 13:40:32] debug: 	zh:ember:uart:ash: ---> [FRAME type=RST]
[2025-01-06 13:40:32] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 0/2500
[2025-01-06 13:40:33] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 100/2500
[2025-01-06 13:40:33] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 200/2500
2300/2500
[2025-01-06 13:40:35] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 2400/2500
[2025-01-06 13:40:35] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-01-06 13:40:35] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-01-06 13:40:35] debug: 	zh:ember:uart:ash: ---> [FRAME type=RST]
[2025-01-06 13:40:35] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 0/2500
[2025-01-06 13:40:37] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 2400/2500
[2025-01-06 13:40:38] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-01-06 13:40:38] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-01-06 13:40:38] debug: 	zh:ember:uart:ash: ---> [FRAME type=RST]
[2025-01-06 13:40:38] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 0/2500
[2025-01-06 13:40:38] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 100/2500
[2025-01-06 13:40:40] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 2300/2500
[2025-01-06 13:40:40] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 2400/2500
[2025-01-06 13:40:40] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-01-06 13:40:40] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-01-06 13:40:40] debug: 	zh:ember:uart:ash: ---> [FRAME type=RST]
[2025-01-06 13:40:40] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 0/2500
[2025-01-06 13:40:42] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 2400/2500
[2025-01-06 13:40:43] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-01-06 13:40:43] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2025-01-06 13:40:43] debug: 	zh:ember:uart:ash: ---> [FRAME type=RST]
[2025-01-06 13:40:43] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 0/2500
[2025-01-06 13:40:45] debug: 	zh:ember:uart:ash: Waiting for RSTACK... 2400/2500
[2025-01-06 13:40:45] error: 	z2m: Error while starting zigbee-herdsman
[2025-01-06 13:40:45] error: 	z2m: Failed to start zigbee-herdsman
[2025-01-06 13:40:45] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-01-06 13:40:45] error: 	z2m: Exiting...
[2025-01-06 13:40:45] error: 	z2m: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
    at EmberAdapter.initEzsp (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:670:19)
    at EmberAdapter.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/adapter/ember/adapter/emberAdapter.ts:1533:24)
    at Controller.start (/app/node_modules/.pnpm/[email protected]/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
    at Zigbee.start (/app/lib/zigbee.ts:69:27)
    at Controller.start (/app/lib/controller.ts:142:13)
    at start (/app/index.js:161:5)
Please assist? Should I create a new installation?
I’m closing in on that step, but it’s a bit of work since I have quite a few devices…
I do appreciate the openness of the HA code and architecture, but the threshold to get everything to work is not zero…
Regards, Kenneth
You just updated to v2.02 without reading the release notes. No need to reinstall anything. There are just some config changes you must make as detailed here: Zigbee2MQTT 2.0.0 breaking changes · Koenkk/zigbee2mqtt · Discussion #24198 · GitHub
