Zigbee ZBWS02 switch
Has anyone explored if these can be made to work in HA.
I use a Conbee and have not managed to pair it to that or to the Smartlife app - which makes reference to needing a gateway which worries me.
according to this site it says it’s confirmed to work in Deconz and it doesn’t mention a hub is required:
You can only pair it in Smartlife if you use a Tuya hub. But if you have a Conbee and use the Deconz, ZHA or Zigbee2MQTT Zigbee stack, no need to pair in Smartlife. Just pair with your existing Zigbee stack.
Thanks for responding. I had seen that web site and its reference to working with deconz / conbee2.
Not succeeded tho’, despite many pressings of the ‘net key’ buton on the switch.
Switch goes into pairing mode and flashes its lights but phoscon never sees it.
Try to pair it close to the coordinator.
Yep, tried that. Thanks for keeping up with ideas.
Well, I kept trying and strangely trying to pair it as a sensor using phoscon made it succeed. It then showed up as a switch.
In HA it then showed up as two disabled deconz switches. However, enabling them has not resulted in them working.
They don’t show up in a deconz_event monitor either.
Remaining hair getting torn !!
