Zigbee ZHA and HA Yellow
First of all Hello everyone.
I’m new to the forum and this is my first topic. I hope that is the right way to go. Otherwise thank you for telling me.
Sorry for my bad English. I am Spanish and I live in France
Here I acquired Home Assistant Yellow 10 days ago, to leave my Nas Synology a little alone.
So I reinstalled HA following the procedure for yellow. No worries everything seems OK. I put together a backup and found all my little ones.
The installation went perfectly.
But I have a problem with the integration of the Yellow Zigbee Home Automation module installed on the board.
I’ve been trying to start the integration for a week but I still get the same error: “Unknown error occurred”
If I try to install it manually it’s the same. Always an error: “Login failed”
I have redone several times the complete reinstallation of the Home assistant system I still have the same problem !!
When I look at the newspaper there is:
Home Assistant Core
‘Received error: [Errno 101] Network unreachable, transport: <_SelectorDatagramTransport fd=32 read=polling write=<idle, bufsize=0>>, socket: <asyncio.TransportSocket fd=32, family=2, type=2, proto=0, laddr=(‘0.0.0.0’, 60463)>
19:07:40 – (ERROR) runner.py’
‘Error handling request’
‘19:07:37 – (ERROR) runner.py’
I don’t understand ANYTHING. And I must admit that I am very disappointed czar I thought that having the zigbee module on the yellow card would make things transparent.
In short if someone has a serious track to offer me I am a taker because I am wondering if the module on the map does not have a problem.
my configuration for zigbee
‘adapter: ezsp, port: /dev/ttyAMA1, baudrate: 115200’
